주요 콘텐츠로 건너뛰기
LG VX8560 Keypad Replacement
필요한 것
  1. LG VX8560 Keypad Replacement, Keypad: 1 단계, 이미지 1/2 LG VX8560 Keypad Replacement, Keypad: 1 단계, 이미지 2/2
    • Remove the battery by sliding the battery cover off the phone.
    • Unscrew all 4 screws along the edge of the phone using the Philips #00 Screwdriver.
  2. LG VX8560 Keypad Replacement: 2 단계, 이미지 1/2 LG VX8560 Keypad Replacement: 2 단계, 이미지 2/2
    • Insert the iFixit Opening Tool between the phone’s keypad cover and the back cover, and gently pull apart.
    • Be careful with the motherboard; don’t let it detach.
  3. LG VX8560 Keypad Replacement: 3 단계, 이미지 1/1
    • Insert the new keypad into the cover frame and check the dimensions.
  4. LG VX8560 Keypad Replacement: 4 단계, 이미지 1/2 LG VX8560 Keypad Replacement: 4 단계, 이미지 2/2
    • Gently snap the cover frame back to the right position.
    • Replace the screws using the Phillips #00 Screwdriver.
    • Insert the battery and snap the back cover on.
결론
The keypad is successfully replaced.
다른 한 분이 해당 안내서를 완성하였습니다.
Jack Foley
회원 가입일: 04/25/13
37 평판
안내서 3개 작성하였습니다
Cal Poly, Team 13-62, Johann Spring 2013 Cal Poly, Team 13-62, Johann Spring 2013 회원
CPSU-JOHANN-S13S13G62
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 9
전체 시간: 264
