주요 콘텐츠로 건너뛰기
LG VX8560 Side Key Replacement
필요한 것
  1. LG VX8560 Side Key Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the phone over so its backside is facing up
  2. LG VX8560 Side Key Replacement: 2 단계, 이미지 1/1
    • Push the battery cover from the indentation and slide the battery cover away from phone to remove battery cover
  3. LG VX8560 Side Key Replacement: 3 단계, 이미지 1/2 LG VX8560 Side Key Replacement: 3 단계, 이미지 2/2
    • Remove the battery from the phone
  4. LG VX8560 Side Key Replacement, Side Keys: 4 단계, 이미지 1/2 LG VX8560 Side Key Replacement, Side Keys: 4 단계, 이미지 2/2
    • Using a Phillips #00 screwdriver, remove all four screws that are visible along the edge of the phone
  5. LG VX8560 Side Key Replacement: 5 단계, 이미지 1/3 LG VX8560 Side Key Replacement: 5 단계, 이미지 2/3 LG VX8560 Side Key Replacement: 5 단계, 이미지 3/3
    • Find the seam between the phone’s keypad cover and back cover, and slide a plastic pry tool along the edge to gently pry the two pieces apart without completely separating them.
    • The motherboard should be visible. Do not separate the two covers. They should be held together by a screw at the axis of the phone.
  6. LG VX8560 Side Key Replacement: 6 단계, 이미지 1/2 LG VX8560 Side Key Replacement: 6 단계, 이미지 2/2
    • Place the side keys so that they are aligned with the silver circles located on the side of the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kevin
회원 가입일: 04/18/13
7 평판
안내서 2개 작성하였습니다
Cal Poly, Team 13-62, Johann Spring 2013 Cal Poly, Team 13-62, Johann Spring 2013 회원
CPSU-JOHANN-S13S13G62
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 30
전체 시간: 241
