주요 콘텐츠로 건너뛰기
LG VX8700 Keypad Replacement
필요한 것
  1. LG VX8700 Keypad Replacement, Battery: 1 단계, 이미지 1/2 LG VX8700 Keypad Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure the phone is completely off.
    • Remove the back cover by sliding the tab away from the phone using one finger.
  2. LG VX8700 Keypad Replacement: 2 단계, 이미지 1/2 LG VX8700 Keypad Replacement: 2 단계, 이미지 2/2
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, make sure to align the metal pins with those of the phone.
  3. LG VX8700 Keypad Replacement, Keypad: 3 단계, 이미지 1/2 LG VX8700 Keypad Replacement, Keypad: 3 단계, 이미지 2/2
    • Remove the nine 4 mm screws from the back cover with a Phillips #0 screwdriver.
  4. LG VX8700 Keypad Replacement: 4 단계, 이미지 1/2 LG VX8700 Keypad Replacement: 4 단계, 이미지 2/2
    • Insert the tip of the iFixit opening tool into the small notch on the side of the case.
    • Slide the opening tool along the seam and around the edge of the phone to separate the case.
  5. LG VX8700 Keypad Replacement: 5 단계, 이미지 1/1
    • Separate the two halves of the phone.
    • The back of the phone, which houses the motherboard and keypad, is displayed on the left.
    • The plastic casing is displayed on the right.
  6. LG VX8700 Keypad Replacement: 6 단계, 이미지 1/3 LG VX8700 Keypad Replacement: 6 단계, 이미지 2/3 LG VX8700 Keypad Replacement: 6 단계, 이미지 3/3
    • Hold the phone casing with one hand and the keypad assembly with the other.
    • Separate the phone casing from the keypad/motherboard.
  7. LG VX8700 Keypad Replacement: 7 단계, 이미지 1/2 LG VX8700 Keypad Replacement: 7 단계, 이미지 2/2
    • Pull the two boards apart to separate the keypad from the motherboard.
결론
tnscholz
회원 가입일: 01/20/12
18 평판
안내서 1개 작성함
Cal Poly, Team 8-16, Maness Winter 2012 Cal Poly, Team 8-16, Maness Winter 2012 회원
CPSU-MANESS-W12S8G16
4 회원들
안내서 14개 작성하였습니다
댓글 한 개
When I separated the two halves a small brass piece came out and your instructions do not show nor mention what this is or where it goes. Not even a caution about it coming out upon separation of the halves. It appears to belong on one of the screw posts and because it is brass I believe it is supposed to complete a circuit.
gfon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 724
