주요 콘텐츠로 건너뛰기
LG VX9800 Logic Board Replacement
필요한 것
  1. LG VX9800 Logic Board Replacement, Front Keypad: 1 단계, 이미지 1/1
    • Remove the two triangular pads at the top of the two speakers.
    • These pads have adhesive to keep them situated, so you may want to use a fine-tipped object, such as a screwdriver or a pen, to remove them. It is easiest to place the fine-tipped object in the small indent in the corner of these pads.
  2. LG VX9800 Logic Board Replacement: 2 단계, 이미지 1/1
    • Remove the two rubber cylinders from their shafts. These cover more screws.
    • This requires a little more effort, so you may need to "dig" them out.
  3. LG VX9800 Logic Board Replacement: 3 단계, 이미지 1/1
    • Now remove the four screws.
    • The screws are small, so put them somewhere that you can easily keep track of them.
  4. LG VX9800 Logic Board Replacement: 4 단계, 이미지 1/1
    • Starting on the side with blue square, pry the faceplate upwards with the flat end of a spudger.
    • Continue to slide the flat edge along the seam of the faceplate.
    • You should hear popping or snapping noises as the faceplate is being removed.
  5. LG VX9800 Logic Board Replacement: 5 단계, 이미지 1/2 LG VX9800 Logic Board Replacement: 5 단계, 이미지 2/2
    • The faceplate is attached by wires, so do not pull the faceplate very far away from the phone.
  6. LG VX9800 Logic Board Replacement: 6 단계, 이미지 1/3 LG VX9800 Logic Board Replacement: 6 단계, 이미지 2/3 LG VX9800 Logic Board Replacement: 6 단계, 이미지 3/3
    • The faceplate is still attached through speakers that travel from the ear-piece to the motherboard.
    • Carefully wedge the flat or pointed end of the spudger beneath the ear-piece and the faceplate.
    • This may require a bit of force, as the ear-piece is stuck to the faceplate with adhesive.
  7. LG VX9800 Logic Board Replacement: 7 단계, 이미지 1/1
    • The faceplate and keypad can now be completely removed from the phone.
  8. LG VX9800 Logic Board Replacement, Logic Board: 8 단계, 이미지 1/3 LG VX9800 Logic Board Replacement, Logic Board: 8 단계, 이미지 2/3 LG VX9800 Logic Board Replacement, Logic Board: 8 단계, 이미지 3/3
    • Use Spudger to pry against the side side of the phone and the logic board to release it.
    • The logic board is connected to a thin silver piece of metal highlighted with a blue square in the photo. Pry against this piece and the phone to release the board.
    • The logic board is connected to the phone and speaker with the set of connections highlighted with a red circle. Do not yank on the board once its released
  9. LG VX9800 Logic Board Replacement: 9 단계, 이미지 1/1
    • Remove 4 wires from logic board. Replace board by soldering back the 4 wires and you're done!
    • This step requires soldering. Only do this step if you are OK with soldering small wires.
결승점
Steven Clark
회원 가입일: 01/21/10
29 평판
안내서 2개 작성하였습니다
Cal Poly, Team 16-32, Maness Winter 2010 Cal Poly, Team 16-32, Maness Winter 2010 회원
CPSU-MANESS-W10S16G32
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,540
