주요 콘텐츠로 건너뛰기
LG Volt Screen Replacement
필요한 것
  1. LG Volt Screen Replacement, Screen: 1 단계, 이미지 1/3 LG Volt Screen Replacement, Screen: 1 단계, 이미지 2/3 LG Volt Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Pry back cover with finger in the crease.
    • Remove back casing.
  2. LG Volt Screen Replacement: 2 단계, 이미지 1/3 LG Volt Screen Replacement: 2 단계, 이미지 2/3 LG Volt Screen Replacement: 2 단계, 이미지 3/3
    • With your finger, pry the battery out through the crease made for removal.
  3. LG Volt Screen Replacement: 3 단계, 이미지 1/3 LG Volt Screen Replacement: 3 단계, 이미지 2/3 LG Volt Screen Replacement: 3 단계, 이미지 3/3
    • Remove all 11 (4mm) screws with the JIS #000 screwdriver.
    • There are three screws on top, three above the battery, one next to the battery, one under the battery and three at the bottom of the phone.
  4. LG Volt Screen Replacement: 4 단계, 이미지 1/3 LG Volt Screen Replacement: 4 단계, 이미지 2/3 LG Volt Screen Replacement: 4 단계, 이미지 3/3
    • Use the plastic opening tool to remove the back housing from the frame of the phone.
  5. LG Volt Screen Replacement: 5 단계, 이미지 1/2 LG Volt Screen Replacement: 5 단계, 이미지 2/2
    • Carefully lift all the indicated tabs.
    • Carefully unplug the marked cables.
  6. LG Volt Screen Replacement: 6 단계, 이미지 1/2 LG Volt Screen Replacement: 6 단계, 이미지 2/2
    • Remove motherboard carefully.
  7. LG Volt Screen Replacement: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using the precision tweezers set lift the copper tab located on the right side of the device.
  8. LG Volt Screen Replacement: 8 단계, 이미지 1/2 LG Volt Screen Replacement: 8 단계, 이미지 2/2
    • Using a JIS #000 screwdriver, remove the 1 (4mm) screw on right side under copper tab.
    • Using a JIS #000 screwdriver, remove the 1 (4mm) screw on bottom left under battery tray.
  9. LG Volt Screen Replacement: 9 단계, 이미지 1/3 LG Volt Screen Replacement: 9 단계, 이미지 2/3 LG Volt Screen Replacement: 9 단계, 이미지 3/3
    • Disconnect the white and black cables as indicated using the precision tweezers set.
    • Lift indicated flap as shown.
  10. LG Volt Screen Replacement: 10 단계, 이미지 1/3 LG Volt Screen Replacement: 10 단계, 이미지 2/3 LG Volt Screen Replacement: 10 단계, 이미지 3/3
    • Use the plastic opening tool to carefully lift the charger assembly from the phone.
    • Start from the copper tab and continue in a clockwise direction.
    • Once it is loose remove the assembly from the phone.
  11. LG Volt Screen Replacement: 11 단계, 이미지 1/1
    • Heat up iOpener for 30 seconds in the microwave.
  12. LG Volt Screen Replacement: 12 단계, 이미지 1/2 LG Volt Screen Replacement: 12 단계, 이미지 2/2
    • Place iOpener on right side of the screen with the phone facing up for 90 seconds.
    • If necessary, heat up the iOpener for an additional 30 seconds in the microwave.
    • Place iOpener on left side of the screen with the phone facing up for 90 seconds.
  13. LG Volt Screen Replacement: 13 단계, 이미지 1/3 LG Volt Screen Replacement: 13 단계, 이미지 2/3 LG Volt Screen Replacement: 13 단계, 이미지 3/3
    • Once the phone is hot, use the small, pointy tipped metal spudger to remove the adhesive.
    • Once removed, use the large, flat tipped metal spudger to pry the screen off carefully.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Adrian Soldan
회원 가입일: 09/25/17
464 평판
안내서 4개 작성하였습니다
USF Tampa, Team S3-G3, Cannon Fall 2017 USF Tampa, Team S3-G3, Cannon Fall 2017 회원
USFT-CANNON-F17S3G3
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 7
전체 시간: 917
