Turn over the phone so the front screen is facing down and the back side is up.
  • Turn over the phone so the front screen is facing down and the back side is up.
댓글 쓰기
Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
  • Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
댓글 쓰기
  • To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
  • Insert the top of the battery, with the two plastic tabs, into their respective holes in the top
  • Then press down on the bottom of the battery and it should snap into place
댓글 쓰기
결론
Michelle
회원 가입일: 2012년 04월 10일
17 평판
안내서 3개 작성하였습니다
Cal Poly, Team 17-26, Amido Spring 2012 Cal Poly, Team 17-26, Amido Spring 2012 회원
CPSU-AMIDO-S12S17G26
4 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 270
