주요 콘텐츠로 건너뛰기
LG Voyager Keyboard Replacement
필요한 것
  1. LG Voyager Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Turn over the phone so the front screen is facing down and the back side is up.
  2. LG Voyager Keyboard Replacement: 2 단계, 이미지 1/1
    • Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
  3. LG Voyager Keyboard Replacement: 3 단계, 이미지 1/1
    • To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
    • Insert the top of the battery, with the two plastic tabs, into their respective holes in the top
    • Then press down on the bottom of the battery and it should snap into place
  4. LG Voyager Keyboard Replacement, Keyboard: 4 단계, 이미지 1/2 LG Voyager Keyboard Replacement, Keyboard: 4 단계, 이미지 2/2
    • First remove the rubber stoppers covering the screws on the back of the phone by prying them up and away from the phone.
  5. LG Voyager Keyboard Replacement: 5 단계, 이미지 1/2 LG Voyager Keyboard Replacement: 5 단계, 이미지 2/2
    • Remove the 3.61mm length, Phillips screws from the back of the phone using the #00 screwdriver.
  6. LG Voyager Keyboard Replacement: 6 단계, 이미지 1/2 LG Voyager Keyboard Replacement: 6 단계, 이미지 2/2
    • Now pry open the back of the phone.
    • Make sure that you use the plastic opening tool to go around the entire phone to help open the phone.
  7. LG Voyager Keyboard Replacement: 7 단계, 이미지 1/2 LG Voyager Keyboard Replacement: 7 단계, 이미지 2/2
    • Carefully separate the keyboard from the top of the phone.
    • Be careful not to break the ribbon cable.
  8. LG Voyager Keyboard Replacement: 8 단계, 이미지 1/1
    • Detach the keyboard from the phone by taking off the little metal latches.
    • When replacing the old keyboard with a new one you will have to solder the metal latches to the new board.
결론
Lance Collins
회원 가입일: 04/12/12
7 평판
안내서 1개 작성함
Cal Poly, Team 17-26, Amido Spring 2012 Cal Poly, Team 17-26, Amido Spring 2012 회원
CPSU-AMIDO-S12S17G26
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 430
