소개
This guide will show you how to disassemble the Lg Vu CU920 to replace a broken speaker. You will need to keep track of small screws, remove small components from the motherboard, and use a plastic opening tool to remove the plastic bezel.
필요한 것
Remove the back cover by firmly pressing against the indent on the back panel. Slide the cover downward and off the phone.
Remove the two 3.5 mm screws above the battery port with a Phillips #00 screwdriver.
Remove the 3.5mm screw holding the antenna guide in place with a Philips #00 screwdriver.
Slide the antenna out to the edge, and remove the plastic tubing by gently pulling it out from the opposite end of the antenna.
Locate the speaker on the inside of the plastic casing.
Use a plastic opening tool to pry the speaker out. It is attached with an adhesive.
Install a replacement speaker in place of the old one.
다른 한 분이 해당 안내서를 완성하였습니다.
