주요 콘텐츠로 건너뛰기
LG WM3050CW Control Panel Replacement
필요한 것
  1. LG WM3050CW Control Panel Replacement, Safety Precautions: 1 단계, 이미지 2개 중 1개 LG WM3050CW Control Panel Replacement, Safety Precautions: 1 단계, 이미지 2개 중 2개
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG WM3050CW Control Panel Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 1개 LG WM3050CW Control Panel Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 2개 LG WM3050CW Control Panel Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 3개
    • Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
  3. LG WM3050CW Control Panel Replacement, Remove the top panel: 3 단계, 이미지 2개 중 1개 LG WM3050CW Control Panel Replacement, Remove the top panel: 3 단계, 이미지 2개 중 2개
    • Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
  4. LG WM3050CW Control Panel Replacement: 4 단계, 이미지 2개 중 1개 LG WM3050CW Control Panel Replacement: 4 단계, 이미지 2개 중 2개
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG WM3050CW Control Panel Replacement, Remove the detergent drawer: 5 단계, 이미지 2개 중 1개 LG WM3050CW Control Panel Replacement, Remove the detergent drawer: 5 단계, 이미지 2개 중 2개
    • Pull the detergent drawer away from the chassis as far as it will go.
  6. LG WM3050CW Control Panel Replacement: 6 단계, 이미지 3개 중 1개 LG WM3050CW Control Panel Replacement: 6 단계, 이미지 3개 중 2개 LG WM3050CW Control Panel Replacement: 6 단계, 이미지 3개 중 3개
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
  7. LG WM3050CW Control Panel Replacement, Disconnect the control panel: 7 단계, 이미지 3개 중 1개 LG WM3050CW Control Panel Replacement, Disconnect the control panel: 7 단계, 이미지 3개 중 2개 LG WM3050CW Control Panel Replacement, Disconnect the control panel: 7 단계, 이미지 3개 중 3개
    • Disconnect the three harness connectors for the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  8. LG WM3050CW Control Panel Replacement, Unfasten the control panel: 8 단계, 이미지 2개 중 1개 LG WM3050CW Control Panel Replacement, Unfasten the control panel: 8 단계, 이미지 2개 중 2개
    • Use a Phillips driver to remove the 16.4 mm-long screw securing the control panel.
  9. LG WM3050CW Control Panel Replacement, Unfasten the detergent dispenser: 9 단계, 이미지 1개 중 1개
    • Use a Phillips driver to remove the two 26.3 mm‑long screws securing the detergent dispenser.
  10. LG WM3050CW Control Panel Replacement, Unclip the control panel: 10 단계, 이미지 3개 중 1개 LG WM3050CW Control Panel Replacement, Unclip the control panel: 10 단계, 이미지 3개 중 2개 LG WM3050CW Control Panel Replacement, Unclip the control panel: 10 단계, 이미지 3개 중 3개
    • Insert a flathead screwdriver between the chassis and the top left corner of the control panel.
    • Twist the screwdriver to release the clips securing the control panel.
    • Repeat this procedure for the remaining clips along the control panel.
  11. LG WM3050CW Control Panel Replacement, Remove the control panel: 11 단계, 이미지 3개 중 1개 LG WM3050CW Control Panel Replacement, Remove the control panel: 11 단계, 이미지 3개 중 2개 LG WM3050CW Control Panel Replacement, Remove the control panel: 11 단계, 이미지 3개 중 3개
    • Lift the control panel upward to completely separate it from the chassis.
    • Pull the control panel away from the chassis, making sure to thread the cables through its slot in the chassis.
    • Remove the control panel.
  12. LG WM3050CW Control Panel Replacement, Unfasten the control panel cover: 12 단계, 이미지 1개 중 1개
    • Flip the control panel over.
    • Use a Phillips driver to remove the seven 16.4 mm-long screws securing the control panel board cover.
  13. LG WM3050CW Control Panel Replacement, Remove the control panel board: 13 단계, 이미지 3개 중 1개 LG WM3050CW Control Panel Replacement, Remove the control panel board: 13 단계, 이미지 3개 중 2개 LG WM3050CW Control Panel Replacement, Remove the control panel board: 13 단계, 이미지 3개 중 3개
    • Pull the control panel board out of its slot and remove it.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
38,528 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,758개를 작성함
2가이드 댓글
Thanks for this guide, it looks very easy to follow. I am thinking about replacing my control panel, it works fine except for one annoying problem, the ‘Start’ button is working intermittently. I need to push Start 2 or 3 times before the washer starts. Has anyone seen this? I may just disassemble the washer and see if I can blow out any debris.
Jimjar - 답글
Hello Jimjar! You can take a shot at blowing stuff out, It is probably the switch on the control panel board that is failing. especially if you don't have trouble with any of the other control buttons. So you might want to start by blowing out the start switch if you have a source of compressed air. While you handle these parts especially blowing air on them, make sure to handle them by the edges, and keep yourself grounded or at least touching something that is grounded frequently. Since the boards are encapsulated (note the honey colored material covering the board) to protect against corrosion, replacing components becomes a chore. So your next step will probably be a replacement control panel board if the cleaning doesn't help. There are services that will repair the board as well; haven't looked into relative cost. You can fix it, and that's a lot better than having to spend for another appliance.
Bill Gilbert -
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 21
지난 30일: 54
전체 시간: 958
