소개
In order to replace your battery case you are going to need the proper tools. There are screws that need to be unscrewed and components that need to be pried open carefully. The tools needed will be plastic opening tools, PH #000 screwdriver and tweezers. With these prepared everything should be ready to start the replacement of the battery case for the LG Watch Urbane.
필요한 것
Push on the band in order to expose the pins
Using tweezers, remove the pins, one on each side, in order to only leave the face of the watch.
이 단계에 사용된 도구:Magnetic Project Mat$19.95
Using a PH000 screwdriver, remove the three screws in order to release the motherboard from the watch.
Using plastic opening tools, remove the four connectors attached to the motherboard
Use color markup to note where the pins are.
Great job of suggesting the magnetic mat!
We did use a color markup!
Rey Diaz -
Using the plastic opening tools, carefully lift up the motherboard.
IGNORE THIS STEP IF ONLY REMOVING MOTHERBOARD: Use the plastic opening tools to carefully remove the battery
when You put a new battery the back cover will not stay in place without glue.
can you suggest a specific type of glue to be used?
Use the PH000 screwdriver to remove the two highlighted screws to release the battery
다른 한 분이 해당 안내서를 완성하였습니다.
This pic is a little dark
Patty Remmell - 답글
