소개
In order to replace your battery you are going to need the proper tools. There are screws that need to be unscrewed and components that need to be pried open carefully. The tools needed will be plastic opening tools, 000PH screwdriver and tweezers. With these prepared everything should be ready to start the replacement of the battery for the LG Watch Urbane.
필요한 것
다른 18명이 해당 안내서를 완성하였습니다.
댓글 11개
"pried" not "pryed"
The reassembly requires gluing the back together. How do you get the glue?
