소개
In order to replace your screen you are going to need the proper tools. There are screws that need to be unscrewed and components that need to be pried open carefully. The tools needed will be plastic opening tools, PH #000 screwdriver and tweezers. With these prepared everything should be ready to start the replacement of the screen for the LG Watch Urbane.
필요한 것
이 단계에 사용된 도구:Magnetic Project Mat$19.95
Now that you have removed the motherboard and battery, it is time to remove the dock connector.
Using a PH000 screwdriver, remove the two screws in order to release the dock connector from the watch.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
where i can find watch urbane display ?
Does anyone know where to buy the display?
