소개
This guide will show you how to replace the charging port on a LG X Power smartphone.
필요한 것
Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
Pull the cameras out to remove them.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 한 개
Where can i get the charging port part? There are so many different usb female ports.
