주요 콘텐츠로 건너뛰기
LG X Power Loud Speaker Replacement
필요한 것
  1. LG X Power Loud Speaker Replacement, LG X Power Disassembly: 1 단계, 이미지 1/2 LG X Power Loud Speaker Replacement, LG X Power Disassembly: 1 단계, 이미지 2/2
    • Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
  2. LG X Power Loud Speaker Replacement: 2 단계, 이미지 1/2 LG X Power Loud Speaker Replacement: 2 단계, 이미지 2/2
    • Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
  3. LG X Power Loud Speaker Replacement: 3 단계, 이미지 1/2 LG X Power Loud Speaker Replacement: 3 단계, 이미지 2/2
    • Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
    • With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
  4. LG X Power Loud Speaker Replacement, Loud Speaker: 4 단계, 이미지 1/2 LG X Power Loud Speaker Replacement, Loud Speaker: 4 단계, 이미지 2/2
    • Pry the loud speaker out of the mid-frame with a plastic opening tool.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Chad Sears
회원 가입일: 02/14/18
1,170 평판
안내서 5개 작성하였습니다
USF Tampa, Team S3-G6, Nance Spring 2018 USF Tampa, Team S3-G6, Nance Spring 2018 회원
USFT-NANCE-S18S3G6
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 15
전체 시간: 1,344
