소개
This guide will provide the steps of removing the back casing of the device and removing the damaged battery.
필요한 것
Power down the device and make sure that it is turned off.
Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
Gently twist tool clockwise until the back case pops open [this will create a small gap].
Slide the tool along the gap around the entire device.
다른 한 분이 해당 안내서를 완성하였습니다.
