주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG X Style Camera Flash Replacement
필요한 것
  1. LG X Style Camera Flash Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Power down the device and make sure that it is turned off.
    • Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
    • Gently twist tool clockwise until the back case pops open [this will create a small gap].
    • Slide the tool along the gap around the entire device.
  2. LG X Style Camera Flash Replacement: 2 단계, 이미지 2개 중 1개 LG X Style Camera Flash Replacement: 2 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool into the indent below the battery, and pry up to lift and remove the battery.
  3. LG X Style Camera Flash Replacement, Screen: 3 단계, 이미지 2개 중 1개 LG X Style Camera Flash Replacement, Screen: 3 단계, 이미지 2개 중 2개
    • With a Phillips #000 screwdriver, remove the twelve 3mm screws.
  4. LG X Style Camera Flash Replacement: 4 단계, 이미지 3개 중 1개 LG X Style Camera Flash Replacement: 4 단계, 이미지 3개 중 2개 LG X Style Camera Flash Replacement: 4 단계, 이미지 3개 중 3개
    • Create a gap with plastic opening tool by applying pressure between glass screen and plastic edge of device.
    • Slide prying tool around entire device beginning toward the top.
    • Lift off and remove the screen from the device.
  5. LG X Style Camera Flash Replacement, Camera Flash: 5 단계, 이미지 2개 중 1개 LG X Style Camera Flash Replacement, Camera Flash: 5 단계, 이미지 2개 중 2개
    • Using a plastic opening tool, lift up display connection until disconnected from the lower right hand of the phone.
    • Carefully lift the metal connection perpendicular to the mother board.
  6. LG X Style Camera Flash Replacement: 6 단계, 이미지 2개 중 1개 LG X Style Camera Flash Replacement: 6 단계, 이미지 2개 중 2개
    • Gently lift the camera ribbon cable until the entire front camera housing is removed.
  7. LG X Style Camera Flash Replacement: 7 단계, 이미지 3개 중 1개 LG X Style Camera Flash Replacement: 7 단계, 이미지 3개 중 2개 LG X Style Camera Flash Replacement: 7 단계, 이미지 3개 중 3개
    • Use the opening tool, gently pry up along the edge of the motherboard.
    • Gently pull up and remove the motherboard from the device.
결론
작성자
3다른 기여자 명과 함께
cecilia morales
회원 가입일: 04/09/18
361 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 41
전체 시간: 503
