주요 콘텐츠로 건너뛰기
LG X Style Top Speaker Replacement
필요한 것
  1. LG X Style Top Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Power down the device and make sure that it is turned off.
    • Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
    • Gently twist tool clockwise until the back case pops open [this will create a small gap].
    • Slide the tool along the gap around the entire device.
  2. LG X Style Top Speaker Replacement: 2 단계, 이미지 1/2 LG X Style Top Speaker Replacement: 2 단계, 이미지 2/2
    • Insert the plastic opening tool into the indent below the battery, and pry up to lift and remove the battery.
  3. LG X Style Top Speaker Replacement, Screen: 3 단계, 이미지 1/2 LG X Style Top Speaker Replacement, Screen: 3 단계, 이미지 2/2
    • With a Phillips #000 screwdriver, remove the twelve 3mm screws.
  4. LG X Style Top Speaker Replacement: 4 단계, 이미지 1/3 LG X Style Top Speaker Replacement: 4 단계, 이미지 2/3 LG X Style Top Speaker Replacement: 4 단계, 이미지 3/3
    • Create a gap with plastic opening tool by applying pressure between glass screen and plastic edge of device.
    • Slide prying tool around entire device beginning toward the top.
    • Lift off and remove the screen from the device.
  5. LG X Style Top Speaker Replacement, Motherboard: 5 단계, 이미지 1/2 LG X Style Top Speaker Replacement, Motherboard: 5 단계, 이미지 2/2
    • Using the plastic opening tool, carefully slide the edge of the tool under the press fit cable connections and lift up to disconnect. Do this for all three ribbon cables.
  6. LG X Style Top Speaker Replacement: 6 단계, 이미지 1/3 LG X Style Top Speaker Replacement: 6 단계, 이미지 2/3 LG X Style Top Speaker Replacement: 6 단계, 이미지 3/3
    • Using the iFixit opening tool, remove the motherboard from the screen by inserting the opening tool under the edge of the motherboard and lifting up.
  7. LG X Style Top Speaker Replacement, Top Speaker: 7 단계, 이미지 1/2 LG X Style Top Speaker Replacement, Top Speaker: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use the nylon-tip reverse tweezers to remove the front facing speaker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 5
30일 전: 10
전체 시간: 157
