주요 콘텐츠로 건너뛰기
소개
After removing the back case, the battery is the next obstacle. Removing the battery is the solution to a lot of problems because it essentially restarts the phone. It is the gateway into the rest of the phone. The battery is a simple obstacle to overcome.
도구
지정된 도구가 없습니다.
부품
지정된 부품이 없습니다.
  1. Turn the phone over so the back side is facing you.
    • Turn the phone over so the back side is facing you.
  2. 안드로이드 수리 키트
    A new screen or battery is one kit away.
    지금 장보기
    안드로이드 수리 키트
    지금 장보기
  3. Placing your thumb on the bottom of the phone, apply pressure to the small ridge in the middle of the phone and push upward towards the camera. The back casing should slide off.
    • Placing your thumb on the bottom of the phone, apply pressure to the small ridge in the middle of the phone and push upward towards the camera.
    • The back casing should slide off.
  4. Using your index finger, pull the top of the battery out first. Place your finger at the top center of the battery in the gap that is provided. Then pull the battery towards yourself. The battery should easily fall out after the top of the battery has been pulled out.
    • Using your index finger, pull the top of the battery out first. Place your finger at the top center of the battery in the gap that is provided. Then pull the battery towards yourself.
    • The battery should easily fall out after the top of the battery has been pulled out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Micaela Saqui
회원 가입일: 2012년 04월 19일
39 평판
안내서 7개 작성하였습니다
Cal Poly, Team 9-41, Regan Spring 2012 Cal Poly, Team 9-41, Regan Spring 2012 회원
CPSU-REGAN-S12S9G41
5 회원들
안내서 16개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 1,138
