주요 콘텐츠로 건너뛰기
LG Xenon Motherboard Replacement
필요한 것
  1. LG Xenon Motherboard Replacement, Back Case: 1 단계, 이미지 1/1
    • Turn the phone over so the back side is facing you.
  2. LG Xenon Motherboard Replacement: 2 단계, 이미지 1/2 LG Xenon Motherboard Replacement: 2 단계, 이미지 2/2
    • Placing your thumb on the bottom of the phone, apply pressure to the small ridge in the middle of the phone and push upward towards the camera.
    • The back casing should slide off.
  3. LG Xenon Motherboard Replacement, Battery: 3 단계, 이미지 1/2 LG Xenon Motherboard Replacement, Battery: 3 단계, 이미지 2/2
    • Using your index finger, pull the top of the battery out first. Place your finger at the top center of the battery in the gap that is provided. Then pull the battery towards yourself.
    • The battery should easily fall out after the top of the battery has been pulled out.
  4. LG Xenon Motherboard Replacement, Motherboard: 4 단계, 이미지 1/2 LG Xenon Motherboard Replacement, Motherboard: 4 단계, 이미지 2/2
    • Unscrew the six 2.4mm Phillips #00 screws (three on the left and three on the right of the phone) to remove the inner back case.
  5. LG Xenon Motherboard Replacement: 5 단계, 이미지 1/1
    • Once all six screws are removed, use the plastic opening tool to carefully pry apart the inner back case. Push the plastic tool underneath the case. Carefully push upward, with the tool, while moving it around the case.
  6. LG Xenon Motherboard Replacement: 6 단계, 이미지 1/2 LG Xenon Motherboard Replacement: 6 단계, 이미지 2/2
    • Remove the camera, lock, and volume buttons from the side of the phone.
  7. LG Xenon Motherboard Replacement: 7 단계, 이미지 1/2 LG Xenon Motherboard Replacement: 7 단계, 이미지 2/2
    • Carefully remove the two 3mm Phillips #00 screws (one on the top and one on the bottom) that are attaching the motherboard to the phone.
  8. LG Xenon Motherboard Replacement: 8 단계, 이미지 1/2 LG Xenon Motherboard Replacement: 8 단계, 이미지 2/2
    • For this next step, carefully lift and remove the motherboard.
    • A connector cable will still be connected to the motherboard upon removing it.
    • Damage to the connector cable will permanently disable phone.
  9. LG Xenon Motherboard Replacement: 9 단계, 이미지 1/2 LG Xenon Motherboard Replacement: 9 단계, 이미지 2/2
    • Carefully unclip the silver metallic tab from the motherboard.
  10. LG Xenon Motherboard Replacement: 10 단계, 이미지 1/2 LG Xenon Motherboard Replacement: 10 단계, 이미지 2/2
    • Once the cable is removed, you have successfully disassembled the motherboard of your phone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Micaela Saqui
회원 가입일: 04/19/12
39 평판
안내서 7개 작성하였습니다
Cal Poly, Team 9-41, Regan Spring 2012 Cal Poly, Team 9-41, Regan Spring 2012 회원
CPSU-REGAN-S12S9G41
5 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,057
