주요 콘텐츠로 건너뛰기
LG Xenon Speaker Replacement
필요한 것
  1. LG Xenon Speaker Replacement, Back Case: 1 단계, 이미지 1/1
    • Turn the phone over so the back side is facing you.
  2. LG Xenon Speaker Replacement: 2 단계, 이미지 1/2 LG Xenon Speaker Replacement: 2 단계, 이미지 2/2
    • Placing your thumb on the bottom of the phone, apply pressure to the small ridge in the middle of the phone and push upward towards the camera.
    • The back casing should slide off.
  3. LG Xenon Speaker Replacement, Battery: 3 단계, 이미지 1/2 LG Xenon Speaker Replacement, Battery: 3 단계, 이미지 2/2
    • Using your index finger, pull the top of the battery out first. Place your finger at the top center of the battery in the gap that is provided. Then pull the battery towards yourself.
    • The battery should easily fall out after the top of the battery has been pulled out.
  4. LG Xenon Speaker Replacement, Motherboard: 4 단계, 이미지 1/2 LG Xenon Speaker Replacement, Motherboard: 4 단계, 이미지 2/2
    • Unscrew the six 2.4mm Phillips #00 screws (three on the left and three on the right of the phone) to remove the inner back case.
  5. LG Xenon Speaker Replacement: 5 단계, 이미지 1/1
    • Once all six screws are removed, use the plastic opening tool to carefully pry apart the inner back case. Push the plastic tool underneath the case. Carefully push upward, with the tool, while moving it around the case.
  6. LG Xenon Speaker Replacement: 6 단계, 이미지 1/2 LG Xenon Speaker Replacement: 6 단계, 이미지 2/2
    • Remove the camera, lock, and volume buttons from the side of the phone.
  7. LG Xenon Speaker Replacement: 7 단계, 이미지 1/2 LG Xenon Speaker Replacement: 7 단계, 이미지 2/2
    • Carefully remove the two 3mm Phillips #00 screws (one on the top and one on the bottom) that are attaching the motherboard to the phone.
  8. LG Xenon Speaker Replacement: 8 단계, 이미지 1/2 LG Xenon Speaker Replacement: 8 단계, 이미지 2/2
    • For this next step, carefully lift and remove the motherboard.
    • A connector cable will still be connected to the motherboard upon removing it.
    • Damage to the connector cable will permanently disable phone.
  9. LG Xenon Speaker Replacement: 9 단계, 이미지 1/2 LG Xenon Speaker Replacement: 9 단계, 이미지 2/2
    • Carefully unclip the silver metallic tab from the motherboard.
  10. LG Xenon Speaker Replacement: 10 단계, 이미지 1/2 LG Xenon Speaker Replacement: 10 단계, 이미지 2/2
    • Once the cable is removed, you have successfully disassembled the motherboard of your phone.
  11. LG Xenon Speaker Replacement, Keyboard: 11 단계, 이미지 1/1
    • Turn the motherboard over and carefully remove the keypad from the motherboard.
    • The keyboard may be sitting loosely in the case (not attached to the motherboard). Carefully remove keyboard from case.
  12. LG Xenon Speaker Replacement, LCD: 12 단계, 이미지 1/1
    • After removing the motherboard and keyboard, unscrew eight 1.6mm Phillips #00 screws in the middle of the phone.
  13. LG Xenon Speaker Replacement: 13 단계, 이미지 1/1
    • Remove slider piece.
    • Pay close attention that you don’t lose the spring.
    • Carefully remove the spring.
  14. LG Xenon Speaker Replacement: 14 단계, 이미지 1/2 LG Xenon Speaker Replacement: 14 단계, 이미지 2/2
    • Remove six 2.25mm Phillips #00 screws along the outside of the case.
  15. LG Xenon Speaker Replacement: 15 단계, 이미지 1/2 LG Xenon Speaker Replacement: 15 단계, 이미지 2/2
    • Using the plastic opening tool, carefully open and remove the case. Slide the tool along the edge and pry upwards to open.
  16. LG Xenon Speaker Replacement: 16 단계, 이미지 1/1
    • Remove the black electrical tape holding the LCD to the screen.
  17. LG Xenon Speaker Replacement: 17 단계, 이미지 1/1
    • Un-clasp the small tab in the top right corner.
  18. LG Xenon Speaker Replacement: 18 단계, 이미지 1/3 LG Xenon Speaker Replacement: 18 단계, 이미지 2/3 LG Xenon Speaker Replacement: 18 단계, 이미지 3/3
    • Unhook the LCD from tabs on the bottom using the plastic opening tool.
    • Remove the LCD. Be careful, the LCD screen is fragile.
  19. LG Xenon Speaker Replacement, Speaker: 19 단계, 이미지 1/2 LG Xenon Speaker Replacement, Speaker: 19 단계, 이미지 2/2
    • The speaker is attached to the top of the LCD.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Micaela Saqui
회원 가입일: 04/19/12
39 평판
안내서 7개 작성하였습니다
Cal Poly, Team 9-41, Regan Spring 2012 Cal Poly, Team 9-41, Regan Spring 2012 회원
CPSU-REGAN-S12S9G41
5 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 14
전체 시간: 849
