주요 콘텐츠로 건너뛰기
LG env2 vx9100 Camera Replacement
필요한 것
  1. LG env2 vx9100 Camera Replacement, Battery: 1 단계, 이미지 1/3 LG env2 vx9100 Camera Replacement, Battery: 1 단계, 이미지 2/3 LG env2 vx9100 Camera Replacement, Battery: 1 단계, 이미지 3/3
    • Before disassembling your phone, be sure it is powered off to avoid minor electric shock or possible fire.
    • Place the phone face down on the table.
    • Use your fingernail or an opening tool to pull down the tab below the battery.
    • Lift the battery out.
  2. LG env2 vx9100 Camera Replacement, Back Panel: 2 단계, 이미지 1/2 LG env2 vx9100 Camera Replacement, Back Panel: 2 단계, 이미지 2/2
    • Locate the five rubber covers on the back panel of the phone.
    • Use the metal probe to pop out each rubber cover to reveal the screws underneath.
  3. LG env2 vx9100 Camera Replacement: 3 단계, 이미지 1/2 LG env2 vx9100 Camera Replacement: 3 단계, 이미지 2/2
    • Locate the six 2.5mm screws on the back panel of the phone.
    • Use a #00 Phillips screwdriver to remove each 2.5mm screw.
  4. LG env2 vx9100 Camera Replacement: 4 단계, 이미지 1/2 LG env2 vx9100 Camera Replacement: 4 단계, 이미지 2/2
    • Locate the seam around the edge of the phone.
    • Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Work your way around the phone until all tabs are released.
    • Remove the back panel of the phone.
  5. LG env2 vx9100 Camera Replacement, Camera: 5 단계, 이미지 1/2 LG env2 vx9100 Camera Replacement, Camera: 5 단계, 이미지 2/2
    • Locate the ribbon attached to the lens of the camera.
    • Place the plastic opening tool in between the logic board and ribbon.
    • Lift up the plastic opening to detach the ribbon from the logic board.
  6. LG env2 vx9100 Camera Replacement: 6 단계, 이미지 1/2 LG env2 vx9100 Camera Replacement: 6 단계, 이미지 2/2
    • Place the plastic opening tool in between the lens and the logic board.
    • Detach the lens from the logic board using the plastic opening tool by popping it out.
    • Take the entire lens and ribbon off of the logic board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Reed Williston
회원 가입일: 09/26/12
34 평판
안내서 7개 작성하였습니다
Cal Poly, Team 16-55, Forte Fall 2012 Cal Poly, Team 16-55, Forte Fall 2012 회원
CPSU-FORTE-F12S16G55
5 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 441
