소개
In this guide you will be removing the front panel from the rest of the phone to access the front keyboard.
도구
부품
부품은 필요하지 않습니다.
Place the phone facedown on the table.
Use your fingernail (or a small screw driver) to pull down the tab below the battery.
Lift the battery out.
Locate the five rubber covers on the back panel of the phone.
Use the metal probe to pop out each rubber cover to reveal the screws underneath.
Locate the rubber covers at the top two corners of the inside of the phone.
Use the metal probe to remove the rubber covers to reveal the 2.5mm screws.
Place the front panel so that the buttons face upwards.
Push on the buttons to remove the keyboard from the front cover.
다른 2명이 해당 안내서를 완성하였습니다.
