필요한 것
LG Washer, OE error code message. Washing cycle doesn't finish, water doesn't drain. CLOGGED DRAIN PUMP FILTER.
Related video: https://www.facebook.com/100004990830507...
To assist in opening the filter cover, we can use a blunt knife or a flat screwdriver.
The pump is located in the bottom tray, we need to turn the filter cap a couple of turns, WITHOUT UNSCREWING IT COMPLETELY, this way we are slowly opening and closing to drain the water slowly without flooding the room.
It is very important to check the filter with a flashlight and make sure there are no objects left in the gap or the drain pump propeller. Also, you can slowly stick your fingers in the tube on the left side, where the water gets to the pump, if you feel any objects they have to be removed.
This is a home made tool that I also use to check the pump's propeller without having to remove it.
This is a PVC tube, 16 mm by 20 cm (tube used for electrical installations). I used a saw and a small file to make four slits on one end so I can grip the propeller and confirm if it rotates or not.
The tube is inserted to grip the propeller, then it needs to be rotated to confirm if there is any issue or resistance when turning (damaged motor).
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
