주요 콘텐츠로 건너뛰기
LG-P970 touch screen Replacement
필요한 것
  1. LG-P970 touch screen Replacement, touch screen: 1 단계, 이미지 1/3 LG-P970 touch screen Replacement, touch screen: 1 단계, 이미지 2/3 LG-P970 touch screen Replacement, touch screen: 1 단계, 이미지 3/3
    • remove the back cover
    • remove the battery
    • remove the SIM card
    • remove the µSD card (Memory)
  2. LG-P970 touch screen Replacement: 2 단계, 이미지 1/3 LG-P970 touch screen Replacement: 2 단계, 이미지 2/3 LG-P970 touch screen Replacement: 2 단계, 이미지 3/3
    • remove 7 screws on the back
    • with a tool start to open the back frame
    • and it's now easy to remove the back frame with hand, carefully
  3. LG-P970 touch screen Replacement: 3 단계, 이미지 1/3 LG-P970 touch screen Replacement: 3 단계, 이미지 2/3 LG-P970 touch screen Replacement: 3 단계, 이미지 3/3
    • remove buttons
    • locate the back camera
    • with a tool raise up the led.carefully
  4. LG-P970 touch screen Replacement: 4 단계, 이미지 1/3 LG-P970 touch screen Replacement: 4 단계, 이미지 2/3 LG-P970 touch screen Replacement: 4 단계, 이미지 3/3
    • with a tool disconnect the back camera
    • and remove the camera with your fingers.
  5. LG-P970 touch screen Replacement: 5 단계, 이미지 1/2 LG-P970 touch screen Replacement: 5 단계, 이미지 2/2
    • don't forget to remove the little connector of screen, with a tool, right next to the empty slot of the camera.
  6. LG-P970 touch screen Replacement: 6 단계, 이미지 1/3 LG-P970 touch screen Replacement: 6 단계, 이미지 2/3 LG-P970 touch screen Replacement: 6 단계, 이미지 3/3
    • It's time to remove carefully the tactile screen.
    • don't scratch le LCD!!!
  7. LG-P970 touch screen Replacement: 7 단계, 이미지 1/3 LG-P970 touch screen Replacement: 7 단계, 이미지 2/3 LG-P970 touch screen Replacement: 7 단계, 이미지 3/3
    • the touch panel is glued with double-sided tape. You can remove it with your fingers. carefull with the touch screen connector.
    • cut new double sided tape (1-2mm width), put it on the are and peel it.
  8. LG-P970 touch screen Replacement: 8 단계, 이미지 1/3 LG-P970 touch screen Replacement: 8 단계, 이미지 2/3 LG-P970 touch screen Replacement: 8 단계, 이미지 3/3
    • remove the inside protection on the new touch screen.
    • carefully put the news touch screen on the LG. Take care that the connector goes right through the right hole.
    • to finish, add all part by reading these instructions in reverse ;-)
    • and try if it work !
    How much lcd and touchscreen
    maricel parba - 답글
결론
다른 19명이 해당 안내서를 완성하였습니다.
Fox4EGX
회원 가입일: 10/01/12
545 평판
안내서 1개 작성함
댓글 한 개
Hi. To take the screws out do I need a phillips? Thanks.
schutze61 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 9,673
