주요 콘텐츠로 건너뛰기
LOOKAH Unicorn Erig Battery Replacement Replacement
필요한 것
  1. LOOKAH Unicorn Erig Battery Replacement Replacement, Remove the Glass Bubbler: 1 단계, 이미지 1개 중 1개
    • Lift off the glass bubbler and magnetic ring and place them to one side.
  2. LOOKAH Unicorn Erig Battery Replacement Replacement, Remove Non Slip Pads: 2 단계, 이미지 1개 중 1개
    • Remove the three nonslip pads from the base of the unit.
    • This will expose three small crosshead (phillips) screws
  3. LOOKAH Unicorn Erig Battery Replacement Replacement: 3 단계, 이미지 1개 중 1개
    • Use a small screwdriver to remove the screws
    • Lift off the plastic base to show the battery and components
  4. LOOKAH Unicorn Erig Battery Replacement Replacement, Remove the battery: 4 단계, 이미지 3개 중 1개 LOOKAH Unicorn Erig Battery Replacement Replacement, Remove the battery: 4 단계, 이미지 3개 중 2개 LOOKAH Unicorn Erig Battery Replacement Replacement, Remove the battery: 4 단계, 이미지 3개 중 3개
    • Carefully lift out the batteries.
    • Remove the metal plate the batteries are stuck to
    • Remove the tape holding the batteries together
  5. LOOKAH Unicorn Erig Battery Replacement Replacement, Unsolder batteries: 5 단계, 이미지 3개 중 1개 LOOKAH Unicorn Erig Battery Replacement Replacement, Unsolder batteries: 5 단계, 이미지 3개 중 2개 LOOKAH Unicorn Erig Battery Replacement Replacement, Unsolder batteries: 5 단계, 이미지 3개 중 3개
    • Use a Solder Iron on to heat the solder and remove the cable from the batteries
  6. LOOKAH Unicorn Erig Battery Replacement Replacement, Solder new batteries in place: 6 단계, 이미지 2개 중 1개 LOOKAH Unicorn Erig Battery Replacement Replacement, Solder new batteries in place: 6 단계, 이미지 2개 중 2개
    • Use a soldering iron to connect new battery.
    • Tape the two new batteries back together
    • Click the power button five times to see if the device turns on
  7. LOOKAH Unicorn Erig Battery Replacement Replacement: 8 단계, 이미지 3개 중 1개 LOOKAH Unicorn Erig Battery Replacement Replacement: 8 단계, 이미지 3개 중 2개 LOOKAH Unicorn Erig Battery Replacement Replacement: 8 단계, 이미지 3개 중 3개
    • Replace the double-sided tape on the metal plate and connect it to batteries.
    • Reseat batteries and metal disc, with the metal disc side down into the unit's base. Note the orientation of the batteries. The base cover will not fit on if they are not the correct way around.
    • Line up the base cover and put it in place, with the plastic tab towards the USB port and the screws holes lined up
  8. LOOKAH Unicorn Erig Battery Replacement Replacement, Screw base cover in place: 9 단계, 이미지 2개 중 1개 LOOKAH Unicorn Erig Battery Replacement Replacement, Screw base cover in place: 9 단계, 이미지 2개 중 2개
    • screw the base cover in place, taking care not to overtighten it.
    • Replace the non-slip pads.
결론
작성자
1다른 기여자 명과 함께
James Mash
회원 가입일: 10/09/23
490 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 20
전체 시간: 221
