주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement
필요한 것
  1. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement, Hose: 1 단계, 이미지 1개 중 1개
    • Place the hair dryer on a sturdy surface with its backside facing up.
    • Using a Phillips #1 screwdriver, remove the six 12.7 mm screws from the back of the hair dryer.
  2. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 2 단계, 이미지 1개 중 1개
    • Open the hair dryer, and place the front cover to the side.
  3. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 3 단계, 이미지 2개 중 1개 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 3 단계, 이미지 2개 중 2개
    • Disconnect the clear tube from the hose cuff.
  4. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 4 단계, 이미지 2개 중 1개 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 4 단계, 이미지 2개 중 2개
    • Untwist the hose cuff off the fan opening.
  5. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 5 단계, 이미지 2개 중 1개 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 5 단계, 이미지 2개 중 2개
    • Pull the hose through the hose cuff until it reaches the top of the inner rim.
  6. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 6 단계, 이미지 1개 중 1개
    • Place and twist the hose cuff onto the fan opening.
  7. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 7 단계, 이미지 3개 중 1개 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 7 단계, 이미지 3개 중 2개 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 7 단계, 이미지 3개 중 3개
    • Slide the hose through the clear tube.
    • Slide the clear tube until it meets the rim of the hose cuff.
  8. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 8 단계, 이미지 1개 중 1개
    • Place the hair dryer's front cover on top of the back cover, leaving a finger's width space for the next step.
  9. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 9 단계, 이미지 2개 중 1개 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 9 단계, 이미지 2개 중 2개
    • Align the wire cover to the grooves of the left and right sides of the hair dryer.
    • Pull the cord through the wire opening.
    • Lightly press on the wire cover to secure its placement.
    • Push the front cover down to close the hair dryer.
  10. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 10 단계, 이미지 2개 중 1개 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 10 단계, 이미지 2개 중 2개
    • Carefully flip the hair dryer on its backside.
    • Place a screw in each opening, and screw them until secure.
  11. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 11 단계, 이미지 1개 중 1개
    • Gently pull the hose to ensure it is secure.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Paige Guillory
회원 가입일: 09/21/21
235 평판
안내서 1개를 작성함
2가이드 댓글
Please provide resource for purchasing a replacement bonnet for the Laila Ali LADR5604
Joyce Johnson - 답글
Can I purchase a bonnet replacement for MODEL: LADR5604WM?
Paula Tucker - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 49
전체 시간: 1,339
