주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lamp Switch Replacement
필요한 것
  1. Lamp Switch Replacement, Switch: 1 단계, 이미지 1개 중 1개
    • Unplug the lamp from the wall to reduce the risk of electric shock.
  2. Lamp Switch Replacement: 2 단계, 이미지 1개 중 1개
    • Unscrew the light bulb from the socket then remove the lamp shade.
  3. Lamp Switch Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two screws from the bottom inside the socket. These screws hold the silver threaded socket in place.
  4. Lamp Switch Replacement: 4 단계, 이미지 1개 중 1개
    • When the screws are removed, the threaded socket will pull out.
  5. Lamp Switch Replacement: 5 단계, 이미지 1개 중 1개
    • Unscrew and remove the outer black socket body.
  6. Lamp Switch Replacement: 6 단계, 이미지 1개 중 1개
    • Partially peel back the felt or cork from bottom of the lamp to gain access to power cord. Take care to avoid tearing.
  7. Lamp Switch Replacement: 7 단계, 이미지 1개 중 1개
    • Push a few inches of the power cord upwards to gain slack to work with. Some cords may have a knot tied here which will need loosened to push slack upwards.
  8. Lamp Switch Replacement: 8 단계, 이미지 1개 중 1개
    • Pull the socket base/switch assembly out of the base to gain access to the screw terminals on the sides.
  9. Lamp Switch Replacement: 9 단계, 이미지 1개 중 1개
    • Unscrew the terminals on each side to release the wires. The screws may be retained so they may not come all the way out.
  10. Lamp Switch Replacement: 10 단계, 이미지 1개 중 1개
    • Attach the wires to the new switch assembly. It doesn't matter which wire goes to which terminal. For a secure connection, bend a hook into the end of the wire and orient it on the screw so the hook closes when the screw is tightened.
  11. Lamp Switch Replacement: 11 단계, 이미지 1개 중 1개
    • Position the socket/switch assembly on the base and pull the power cord from the bottom to set the socket in place. Reattach the felt or cork on the bottom of the lamp.
  12. Lamp Switch Replacement: 12 단계, 이미지 1개 중 1개
    • Pushing downward to hold the socket in place, screw the black outer socket back in place to secure the switch.
  13. Lamp Switch Replacement: 13 단계, 이미지 1개 중 1개
    • Set the sliver threaded socket into place. Turn the socket to align the two screw holes.
  14. Lamp Switch Replacement: 14 단계, 이미지 1개 중 1개
    • Screw in the two screws to secure the threaded silver socket into place.
  15. Lamp Switch Replacement: 15 단계, 이미지 1개 중 1개
    • Reattach the lamp shade and screw in the light bulb.
결론
After following these steps to replace a non-working switch, you should again have a functional lamp.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Matt Plueger
회원 가입일: 02/10/16
363 평판
안내서 1개를 작성함
2가이드 댓글
A very nice and clear explanation. Unfortunately the pull chain switch in my lap was riveted to the socket so I had to replace the entire socket. It really was easy though and required less steps than your switch replacement. Here’s a video that shows exactly what I did: https://youtu.be/0fLnUPWzLeI
Thanks!
Scott Clark - 답글 공유
WOW! I almost threw away my fav Lil lamp - vacuuming I tipped over the lamp and it cracked the threaded plastic part - I followed your instructions and now have a nonflickering - fully functioning lamp! Thanks perfect timing
anggnbama - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 117
전체 시간: 14,622
