주요 콘텐츠로 건너뛰기
Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement
필요한 것
  1. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement, Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone: 1 단계, 이미지 1/2 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement, Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone: 1 단계, 이미지 2/2
    • Switch off the grinder's breaker box before performing any maintenance on the machine.
  2. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 2 단계, 이미지 1/2 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 2 단계, 이미지 2/2
    • Lift the yellow guard up to unlock the grindstone access panel.
  3. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 3 단계, 이미지 1/2 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 3 단계, 이미지 2/2
    • Pull the access panel outward to expose the grindstone.
  4. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 4 단계, 이미지 1/2 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 4 단계, 이미지 2/2
    • Remove the twelve bolts securing the grindstone using a ratchet with a 5/16 Hex bit.
  5. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 5 단계, 이미지 1/2 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 5 단계, 이미지 2/2
    • Gently remove the steel hub from the grindstone spindle.
  6. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 6 단계, 이미지 1/2 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 6 단계, 이미지 2/2
    • Carefully remove the grindstone itself from the spindle, making sure to support it from the top and inner ring.
    • Mind your fingers! The grindstone is quite heavy and can cause injury if it is mishandled or dropped.
  7. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 7 단계, 이미지 1/2 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 7 단계, 이미지 2/2
    • Softly sand the hub with 600-grit sandpaper or a wire brush to remove any surface rust.
  8. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 8 단계, 이미지 1/1
    • Although not mandatory, now would be a good time to scrape out any debris that has built up on the inside of the guard.
결론
To reassemble your device, follow these instructions in reverse order starting from step 6.
다른 3명이 해당 안내서를 완성하였습니다.
Andrew Shotwell
회원 가입일: 02/23/16
136 평판
안내서 1개 작성함
Texas Tech, Team 22-3, Rauch Spring 2016 Texas Tech, Team 22-3, Rauch Spring 2016 회원
TTU-RAUCH-S16S22G3
3 회원들
안내서 1개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 19
전체 시간: 557
