주요 콘텐츠로 건너뛰기
HP 15-bs015dx Teardown
동영상 개요
  1. HP 15-bs015dx Teardown, Remove the Battery - Part 1: 1 단계, 이미지 1/3 HP 15-bs015dx Teardown, Remove the Battery - Part 1: 1 단계, 이미지 2/3 HP 15-bs015dx Teardown, Remove the Battery - Part 1: 1 단계, 이미지 3/3
    • Put the laptop facing down
    • Move the left battery safe lock to the right
  2. HP 15-bs015dx Teardown, Remove the Battery - Part 2: 2 단계, 이미지 1/3 HP 15-bs015dx Teardown, Remove the Battery - Part 2: 2 단계, 이미지 2/3 HP 15-bs015dx Teardown, Remove the Battery - Part 2: 2 단계, 이미지 3/3
    • Slide the right battery safe lock to the left
    • This lock is harder than the previous, with this the battery should pop-up.
  3. HP 15-bs015dx Teardown, Remove the 6 visibles screws: 3 단계, 이미지 1/3 HP 15-bs015dx Teardown, Remove the 6 visibles screws: 3 단계, 이미지 2/3 HP 15-bs015dx Teardown, Remove the 6 visibles screws: 3 단계, 이미지 3/3
    • Use a Philips 0 screwdriver
  4. HP 15-bs015dx Teardown, Remove the 4 hidden screws: 4 단계, 이미지 1/3 HP 15-bs015dx Teardown, Remove the 4 hidden screws: 4 단계, 이미지 2/3 HP 15-bs015dx Teardown, Remove the 4 hidden screws: 4 단계, 이미지 3/3
    • Use a straw to take off just enough of the rubber feet of the 4 corners
    • Use a Phillips screwdriver 0
    • Replace each rubber foot in place after removing the screws
    • You will have a total of 10 screws
  5. HP 15-bs015dx Teardown, Remove the DVD unit: 5 단계, 이미지 1/2 HP 15-bs015dx Teardown, Remove the DVD unit: 5 단계, 이미지 2/2
    • It will go out easily with or without a straw
    • You can check the model number
  6. HP 15-bs015dx Teardown, Separate the pieces of the chassis part 1: 6 단계, 이미지 1/3 HP 15-bs015dx Teardown, Separate the pieces of the chassis part 1: 6 단계, 이미지 2/3 HP 15-bs015dx Teardown, Separate the pieces of the chassis part 1: 6 단계, 이미지 3/3
    • Flip the laptop and open it
    • Use a plastic tool or a straw to separate the pieces of the chassis
  7. HP 15-bs015dx Teardown, Separate the pieces of the chassis part 2: 7 단계, 이미지 1/3 HP 15-bs015dx Teardown, Separate the pieces of the chassis part 2: 7 단계, 이미지 2/3 HP 15-bs015dx Teardown, Separate the pieces of the chassis part 2: 7 단계, 이미지 3/3
    • Flip the laptop and separate the inferior cover of the chassis
    • Hard Drive 2.5" SATA
    • 2 RAM memory slots type DDR4 SO-DIMM
    • CPU Intel 7th generation
    • Active heat sink (fan)
    • Wireless card
    • Watch battery, 3V. CR2030
결론
다른 39명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
es en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Marcos Mora
회원 가입일: 12/17/17
3,561 평판
안내서 11개 작성하였습니다
댓글 16개
Se me rompio las bisagras … como se reemplazan ?
Javier Horacio Monti - 답글
No tengo la laptop a mano para tomarle fotos, aunque en el paso 7 se puede ver algo. Depende de la rotura, lo típico que se rompe es la rosca para los tornillos, hay que crear un nueva rosca con material adicional, sin embargo, desconozco el procedimiento. En todo caso, puedes contactarme a mis RRSS que están en mi perfil de ifixit.
Marcos Mora -
Your step by step guide is apt. Thanks
Perebowei Titus Otoru Nigeria
Perebowei Titus Otoru - 답글
Buenas podrías hacer un tutorial desarmando y ensamblando la webcam
Javier - 답글
Saludos, ya entregué la laptop al cliente.
Marcos Mora -
댓글 쓰기
조회 통계:
24 시간 전: 28
7일 전: 261
30일 전: 1,229
전체 시간: 82,407
