주요 콘텐츠로 건너뛰기
Laptop Ram/Memory Replacement
필요한 것
  1. Laptop Ram/Memory Replacement, RAM door: 1 단계, 이미지 1/3 Laptop Ram/Memory Replacement, RAM door: 1 단계, 이미지 2/3 Laptop Ram/Memory Replacement, RAM door: 1 단계, 이미지 3/3
    • Many laptops have a door for the ram. But often, removing the entire back cover is necessary.
    • Remove screws on Ram door.
    • There is now access to the ram.
    • Remember to always remove or disconnect the battery!
  2. Laptop Ram/Memory Replacement, Releasing the SODIMM: 2 단계, 이미지 1/1
    • Push metal tab out of the way. Some laptops have screws instead of tabs.
  3. Laptop Ram/Memory Replacement, Removing the RAM: 3 단계, 이미지 1/3 Laptop Ram/Memory Replacement, Removing the RAM: 3 단계, 이미지 2/3 Laptop Ram/Memory Replacement, Removing the RAM: 3 단계, 이미지 3/3
    • lift up on ram.
    • Pull out of SODIMM socket.
  4. Laptop Ram/Memory Replacement, Removing second stick: 4 단계, 이미지 1/1
    • Repeat with second stick. Sometimes the second stick is layered under the first.
  5. Laptop Ram/Memory Replacement, Replacing the RAM: 5 단계, 이미지 1/1
    • Remember, If only replacing one Stick, to put that stick in DIMM A or DIMM 1.
    • There are five types of laptop laptop ram: DDR, DDR2, DDR3, DDR3L, and DDR4.
    • Make sure that whatever ram your laptop was using is replaced by that same type. Memory is not cross compatible with desktop memory, so make sure that your RAM is SODIMM laptop memory. SODIMMs are usually about 3" long, while desktop DIMMs are about 4"-5" long.
  6. Laptop Ram/Memory Replacement, Putting the Memory Back: 6 단계, 이미지 1/3 Laptop Ram/Memory Replacement, Putting the Memory Back: 6 단계, 이미지 2/3 Laptop Ram/Memory Replacement, Putting the Memory Back: 6 단계, 이미지 3/3
    • Re-insert RAM at a 45 degree angle and push down until clips snap into place or screw back in.
    • Make sure that pins line up correctly and memory is all the way in place.
    • This is incorrect.
    • Replace RAM door.
결승점
다른 11명이 해당 안내서를 완성하였습니다.
George A.
회원 가입일: 12/07/16
21,879 평판
안내서 4개 작성하였습니다
Community Protectors Community Protectors 회원
Community
19 회원들
안내서 24개 작성하였습니다
댓글 2개
Thank you! Your photographs and simple directions gave me the courage to try this. It’s kind of exhilarating to see those memory sticks pop up and then to hear them click in.
Christie Sonmez - 답글
@curiousandcheap I'm glad I could help! It's really one of the simplest upgrades you can do as long as your laptop doesn't specifically block access to the RAM compartment, but most brands make a door like the one shown to make it easier.
George A. - 답글
댓글 쓰기
조회 통계:
24 시간 전: 16
7일 전: 81
30일 전: 347
전체 시간: 24,113
