This is a replacement of a large animal water nipple, this will provide them access to water without them making a huge mess. This guide has ten easy to follow steps to ensure the replacement is done properly.
If there is a leak try placing some more Teflon tape. If this does not fix the issue continue reading this step. If there is no longer a leak, move on.
Leaking from cracks are easily filled with caulking if the container is small. This would only be a temporary fix on a larger container. Due to the weight of the water, the barrel or bucket would need to be replaced.
