주요 콘텐츠로 건너뛰기
Large Animal Water Nipple Replacement
필요한 것
  1. Large Animal Water Nipple Replacement, Large Animal Water Nipple: 1 단계, 이미지 1개 중 1개
    • Empty the container of all water.
  2. Large Animal Water Nipple Replacement: 2 단계, 이미지 1개 중 1개
    • With an adjustable wrench, unscrew the nut on the inside located near the base on the backside of the nipple.
  3. Large Animal Water Nipple Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the mechanism out from the front.
  4. Large Animal Water Nipple Replacement: 4 단계, 이미지 1개 중 1개
    • Ensure there is no damage to the hole that needs to be patched.
    • Cracks or fractures are easily made due to sun damage or forcing the mechanism in or out.
  5. Large Animal Water Nipple Replacement: 5 단계, 이미지 1개 중 1개
    • Use Teflon tape to line the threads of the new nipple.
  6. Large Animal Water Nipple Replacement: 6 단계, 이미지 2개 중 1개 Large Animal Water Nipple Replacement: 6 단계, 이미지 2개 중 2개
    • Place the new nipple in the hole with the peg on top.
  7. Large Animal Water Nipple Replacement: 7 단계, 이미지 1개 중 1개
    • Fill the container slightly to ensure that there are no leaks. Tighten the washer or pull out to see if a crack has formed while replacing.
    • Tighten the washer to see if that is the source of the leak. If not, pull out to see if a crack has formed while replacing.
    • This is a leak in the seal.
  8. Large Animal Water Nipple Replacement: 8 단계, 이미지 1개 중 1개
    • If there is a leak try placing some more Teflon tape. If this does not fix the issue continue reading this step. If there is no longer a leak, move on.
    • Leaking from cracks are easily filled with caulking if the container is small. This would only be a temporary fix on a larger container. Due to the weight of the water, the barrel or bucket would need to be replaced.
  9. Large Animal Water Nipple Replacement: 9 단계, 이미지 1개 중 1개
    • Place and thread the nut on the inside of the container on the backside of the nipple.
  10. Large Animal Water Nipple Replacement: 10 단계, 이미지 1개 중 1개
    • Finally, place the container in the designated place and fill completely.
결승점
작성자
1다른 기여자 명과 함께
Katelyn Root-Nelson
회원 가입일: 04/11/19
181 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 317
