이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
With an adjustable wrench, unscrew the nut on the inside located near the base on the backside of the nipple.
Fill the container slightly to ensure that there are no leaks. Tighten the washer or pull out to see if a crack has formed while replacing.
This is a leak in the seal.
If there is a leak try placing some more Teflon tape. If this does not fix the issue continue reading this step. If there is no longer a leak, move on.
Place and thread the nut on the inside of the container on the backside of the nipple.
Finally, place the container in the designated place and fill completely.
