주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
The default values of the PS1 drives are between 940 - 970 ohms. To read burned CDs you have to go down a bit.
Warning ! Before you work on the open console, be sure to remove the power! Pull the plug!
Reducing the resistance, will increase the wear and tear of the laser ! If you go down in steps of ten and the CD is read correctly do not further reduce the value, that is useless.
CD's MUST be burned with a maximum burning speed of 4x, because the PS1 laser cannot deal with burn errors. If your burner only supports higher speeds, get another one, because then the games will most likely not work.
This Tweak is intended for 7000er consoles (750x, 700x)! Other PS1 consoles may have a bias & gain on the motherboard. If this value is adjusted then there are other instructions for it.
동영상 지침
결론
Feedback and constructive criticism desired.
다른 3명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
TheSupport
회원 가입일: 2016년 03월 27일
71 평판
안내서 1개 작성함
Swap to German ( ENGLISH TRANSLATION)
The default values ​​of the PS1 drives are between 940 - 970 ohms. To read burned CDs you have to go down a bit.Attention ! Before working on the open console, be sure to take the POWER away! Pull the plug!If you reduce the resistance value, the wear of the laser is increased! If you go down in steps of ten and the CD is read correctly does not reduce the value, that does not help.CD's MUST be burned with a maximum burning speed of 4x, because the PS1 laser with burn errors are not clear. If your burner only supports higher speeds, get another one, because then the games will most likely not work.This Tweak is for 7000er consoles intended (750x, 700x)! Other PS1 consoles may have a bias & gain on the motherboard. If this value is adjusted then there are other instructions for it.
Jordon Garcia - 답글
A modern DVD burner drive cant’t burn a CD-R at 4x. I have some old Taiyo Yuden CD-R (the type recommended for burning playstation backups). I was able to burn a game at the lowest allowed speed for that drive - 16x, and it worked just fine in the Playstation (with mod chip).
Leif Behrmann - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 20
30일 전: 101
전체 시간: 1,619
