주요 콘텐츠로 건너뛰기
Lasergrip 1080 Sensor Replacement
필요한 것
  1. Lasergrip 1080 Sensor Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Lasergrip 1080 Sensor Replacement: 2 단계, 이미지 1개 중 1개
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Lasergrip 1080 Sensor Replacement: 3 단계, 이미지 2개 중 1개 Lasergrip 1080 Sensor Replacement: 3 단계, 이미지 2개 중 2개
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Lasergrip 1080 Sensor Replacement, Buttons: 4 단계, 이미지 2개 중 1개 Lasergrip 1080 Sensor Replacement, Buttons: 4 단계, 이미지 2개 중 2개
    • Remove the battery cover from the device by pulling it straight out.
  5. Lasergrip 1080 Sensor Replacement: 5 단계, 이미지 2개 중 1개 Lasergrip 1080 Sensor Replacement: 5 단계, 이미지 2개 중 2개
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Lasergrip 1080 Sensor Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Lasergrip 1080 Sensor Replacement: 7 단계, 이미지 2개 중 1개 Lasergrip 1080 Sensor Replacement: 7 단계, 이미지 2개 중 2개
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Lasergrip 1080 Sensor Replacement: 8 단계, 이미지 1개 중 1개
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
  9. Lasergrip 1080 Sensor Replacement, Etekcity Lasergrip 1080 Trigger Replacement: 9 단계, 이미지 2개 중 1개 Lasergrip 1080 Sensor Replacement, Etekcity Lasergrip 1080 Trigger Replacement: 9 단계, 이미지 2개 중 2개
    • Carefully pull the trigger out.
    • The trigger is spring loaded, so be careful that you do not lose the spring as you pull the trigger out.
    • To put the trigger back in, align the peg with the hole in the handle and align the shaft with the button terminal.
  10. Lasergrip 1080 Sensor Replacement, Sensor: 10 단계, 이미지 1개 중 1개
    • Pull the motherboard out of its slot in the device.
  11. Lasergrip 1080 Sensor Replacement: 11 단계, 이미지 1개 중 1개
    • Using a soldering iron, melt the solder that holds the wires for the sensor to the motherboard.
    • Soldering irons are hot and should only be handled by those who know what they are doing and are wearing proper safety equipment. There is a link to a soldering guide in the Troubleshooting section of the device page.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Carlos Lewis
회원 가입일: 08/27/15
162 평판
안내서 1개를 작성함
USF Tampa, Team 5-1, Blackwell Fall 2015 USF Tampa, Team 5-1, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S5G1
3 회원들
안내서 9개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 1,631
