주요 콘텐츠로 건너뛰기
Lasko 2002W Motor Replacement
필요한 것
  1. Lasko 2002W Motor Replacement, Remove cover: 1 단계, 이미지 1/1
    • Remove the front cage from the fan, exposing the screws.
  2. Lasko 2002W Motor Replacement, Remove screws: 2 단계, 이미지 1/1
    • Remove the 3 screws holding the fan on to the motor housing using a 3/16" philips head screw driver. The length of the screwdriver does not matter.
  3. Lasko 2002W Motor Replacement, Remove motor screws: 3 단계, 이미지 1/1
    • Remove the screws holding the motor onto the fan using the same 3/16" phillips head screwdriver. There are two screws.
    • Once removed, remove the metal part the screws were holding to the motor.
  4. Lasko 2002W Motor Replacement, Remove old motor.: 4 단계, 이미지 1/1
    • Remove the old motor from the fan. No tools are required. The motor can simply be pulled out.
  5. Lasko 2002W Motor Replacement, Place new motor in motor housing.: 5 단계, 이미지 1/1
    • Now that the old motor is removed, a new motor can be placed in the motor housing.
결론
다른 9명이 해당 안내서를 완성하였습니다.
elsa
회원 가입일: 10/11/14
382 평판
안내서 1개 작성함
USF Tampa, Team 1-39, Donnelly Fall 2014 USF Tampa, Team 1-39, Donnelly Fall 2014 회원
USFT-DONNELLY-F14S1G39
1 회원
안내서 1개 작성하였습니다
댓글 한 개
What is the part number for replacement motor? Where do you get it?
Paul Dias - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 47
전체 시간: 3,362
