주요 콘텐츠로 건너뛰기
Le Pan II Charging Port Replacement
필요한 것
  1. Le Pan II Charging Port Replacement, Screen: 1 단계, 이미지 1/2 Le Pan II Charging Port Replacement, Screen: 1 단계, 이미지 2/2
    • Insert metal spudger between front and back panel to pry apart.
    • Continue to pry while moving the metal spudger along the crevice to completely separate two panels.
    • Avoid using metal when opening devices, as it can damage or crack the screen.
  2. Le Pan II Charging Port Replacement: 2 단계, 이미지 1/2 Le Pan II Charging Port Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool to disconnect the flat ribbon cable from the motherboard connector.
    • Disconnect the flat ribbon by gently pulling it out from its connecting port.
  3. Le Pan II Charging Port Replacement: 3 단계, 이미지 1/2 Le Pan II Charging Port Replacement: 3 단계, 이미지 2/2
    • Use the plastic opening tool to disconnect the display cable from its motherboard connector.
    • Disconnect the display cable by gently pulling it out from its connecting port.
  4. Le Pan II Charging Port Replacement: 4 단계, 이미지 1/1
    • Remove grey metal backing from screen.
  5. Le Pan II Charging Port Replacement: 5 단계, 이미지 1/1
    • Flip the tablet so the screen is facing upward, and use the metal spudger to pry apart the screen from the side pieces.
  6. Le Pan II Charging Port Replacement: 6 단계, 이미지 1/1
    • Lift and carefully remove the LCD display from the front cover.
  7. Le Pan II Charging Port Replacement, Charging Port: 7 단계, 이미지 1/1
    • Use the Phillips 00 screwdriver head to unscrew the screws to the motherboard.
    • Reminder: There should be 8 (3.5 mm) screws to the motherboard.
  8. Le Pan II Charging Port Replacement: 8 단계, 이미지 1/1
    • Use the Phillips 00 screwdriver head to unscrew the screws to the fan.
    • Reminder: There should be 4 (1mm) screws to the fan.
  9. Le Pan II Charging Port Replacement: 9 단계, 이미지 1/1
    • Use the metal spudger to pry off the charging port from the motherboard.
결론
Kelly Moniz
회원 가입일: 10/20/16
513 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 6-3, Martin Fall 2016 UMass Dartmouth, Team 6-3, Martin Fall 2016 회원
UMASSD-MARTIN-F16S6G3
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
I have had no luck getting in touch with anyone in the customer service department.I have left several messages but have not heard from anyone yet. I just need to know how I can get a charge port for my daughters tablet. She had it 6 months before the charge port went out.
tashiarmarshall - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 1,218
