주요 콘텐츠로 건너뛰기
Le Pan II Screen Replacement
필요한 것
  1. Le Pan II Screen Replacement, Screen: 1 단계, 이미지 1/2 Le Pan II Screen Replacement, Screen: 1 단계, 이미지 2/2
    • Insert metal spudger between front and back panel to pry apart.
    • Continue to pry while moving the metal spudger along the crevice to completely separate two panels.
    • Avoid using metal when opening devices, as it can damage or crack the screen.
  2. Le Pan II Screen Replacement: 2 단계, 이미지 1/2 Le Pan II Screen Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool to disconnect the flat ribbon cable from the motherboard connector.
    • Disconnect the flat ribbon by gently pulling it out from its connecting port.
  3. Le Pan II Screen Replacement: 3 단계, 이미지 1/2 Le Pan II Screen Replacement: 3 단계, 이미지 2/2
    • Use the plastic opening tool to disconnect the display cable from its motherboard connector.
    • Disconnect the display cable by gently pulling it out from its connecting port.
  4. Le Pan II Screen Replacement: 4 단계, 이미지 1/1
    • Remove grey metal backing from screen.
  5. Le Pan II Screen Replacement: 5 단계, 이미지 1/1
    • Flip the tablet so the screen is facing upward, and use the metal spudger to pry apart the screen from the side pieces.
  6. Le Pan II Screen Replacement: 6 단계, 이미지 1/1
    • Lift and carefully remove the LCD display from the front cover.
결론
Kelly Moniz
회원 가입일: 10/20/16
513 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 6-3, Martin Fall 2016 UMass Dartmouth, Team 6-3, Martin Fall 2016 회원
UMASSD-MARTIN-F16S6G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 299
