주요 콘텐츠로 건너뛰기
Le Pan S Battery Replacement
필요한 것
  1. Le Pan S Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
    • This cover is adjacent to the volume button on the side of the Le Pan S.
  2. Le Pan S Battery Replacement: 2 단계, 이미지 1/2 Le Pan S Battery Replacement: 2 단계, 이미지 2/2
    • Insert the spudger between the front and back panel in order to pry them apart.
    • Do this beside the volume button and the micro SD cover.
    • Pry open the rest of the Le Pan S by dragging the spudger across the side.
  3. Le Pan S Battery Replacement: 3 단계, 이미지 1/1
    • Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
  4. Le Pan S Battery Replacement: 4 단계, 이미지 1/2 Le Pan S Battery Replacement: 4 단계, 이미지 2/2
    • Disconnect the battery from the circuitry and lay it out of the way.
    • The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
    • If you are replacing your battery, make sure to dispose of it properly.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Maria Dole
회원 가입일: 09/17/15
395 평판
안내서 3개 작성하였습니다
IUPUI, Team 2-1, Harley Fall 2015 IUPUI, Team 2-1, Harley Fall 2015 회원
IUPUI-HARLEY-F15S2G1
5 회원들
안내서 10개 작성하였습니다
댓글 5개
where can I purchase a battery for a tc978
Timothy - 답글
Hi Timothy, Did you ever find out where to purchase a battery for your Le Pan S tablet?
jatrussel -
But what do I do when it's not the battery, but is the charger is so loose in the tablet, it won;t charge. Once in a while, I can get it to come on if I happened to hold the charger just right. So disgusting. Can this be fixed.? i have purchased two LePans and neither will charge.
cdboers - 답글
Where can I purchase the battery needed?????????????????
jatrussel - 답글
Thank you Maria!
Easy to take apart. Disconnected/reconnected battery and voila!
All good.
Be well.
Den E
Denny Ehlers - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 6
전체 시간: 5,375
