주요 콘텐츠로 건너뛰기
Le Pan S Volume Rocker Replacement
필요한 것
  1. Le Pan S Volume Rocker Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
    • This cover is adjacent to the volume button on the side of the Le Pan S.
  2. Le Pan S Volume Rocker Replacement: 2 단계, 이미지 1/2 Le Pan S Volume Rocker Replacement: 2 단계, 이미지 2/2
    • Insert the spudger between the front and back panel in order to pry them apart.
    • Do this beside the volume button and the micro SD cover.
    • Pry open the rest of the Le Pan S by dragging the spudger across the side.
  3. Le Pan S Volume Rocker Replacement: 3 단계, 이미지 1/1
    • Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
  4. Le Pan S Volume Rocker Replacement: 4 단계, 이미지 1/2 Le Pan S Volume Rocker Replacement: 4 단계, 이미지 2/2
    • Disconnect the battery from the circuitry and lay it out of the way.
    • The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
    • If you are replacing your battery, make sure to dispose of it properly.
  5. Le Pan S Volume Rocker Replacement, Volume Rocker: 5 단계, 이미지 1/1
    • Remove the four 2.5 mm Phillips #00 head screws from the circuit board near the top of the tablet.
  6. Le Pan S Volume Rocker Replacement: 6 단계, 이미지 1/1
    • Pull out the volume rocker by carefully moving it side to side with your fingers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Wiaam Elkhatib
회원 가입일: 09/17/15
199 평판
안내서 1개 작성함
IUPUI, Team 2-1, Harley Fall 2015 IUPUI, Team 2-1, Harley Fall 2015 회원
IUPUI-HARLEY-F15S2G1
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 12
전체 시간: 230
