주요 콘텐츠로 건너뛰기
Leader Impression i10A-LE Back Facing Camera Replacement
필요한 것
  1. Leader Impression i10A-LE Back Facing Camera Replacement, Back Facing Camera: 1 단계, 이미지 1/2 Leader Impression i10A-LE Back Facing Camera Replacement, Back Facing Camera: 1 단계, 이미지 2/2
    • Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Back Facing Camera Replacement: 2 단계, 이미지 1/3 Leader Impression i10A-LE Back Facing Camera Replacement: 2 단계, 이미지 2/3 Leader Impression i10A-LE Back Facing Camera Replacement: 2 단계, 이미지 3/3
    • Start by prying the back off by using plastic opening tools.
    • Using the plastic tools slide the flat end into the device.
    • Gently pry the back piece until you hear a popping noise.
    • Once the back is loose, remove it from the device and set aside.
  3. Leader Impression i10A-LE Back Facing Camera Replacement: 3 단계, 이미지 1/3 Leader Impression i10A-LE Back Facing Camera Replacement: 3 단계, 이미지 2/3 Leader Impression i10A-LE Back Facing Camera Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Once the back is off, locate the back facing camera.
    • The camera will be in the top left corner.
    • Using the precision tweezers that are bent, gently grab the strip below the camera.
    • slowly lift up until the camera lifts from its spot.
  4. Leader Impression i10A-LE Back Facing Camera Replacement: 4 단계, 이미지 1/3 Leader Impression i10A-LE Back Facing Camera Replacement: 4 단계, 이미지 2/3 Leader Impression i10A-LE Back Facing Camera Replacement: 4 단계, 이미지 3/3
    • Continue slowly lifting with the bent precision tweezers.
    • The bottom half of the camera strip will pop out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Crystal Dorrian
회원 가입일: 09/12/16
231 평판
안내서 2개 작성하였습니다
Western Carolina University, Team 1-3, Virtue Fall 2016 Western Carolina University, Team 1-3, Virtue Fall 2016 회원
WCU-VIRTUE-F16S1G3
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 7
전체 시간: 212
