주요 콘텐츠로 건너뛰기
Leader Impression i10A-LE Battery Pack Replacement
필요한 것
  1. Leader Impression i10A-LE Battery Pack Replacement, Battery Pack: 1 단계, 이미지 1/1
    • Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Battery Pack Replacement: 2 단계, 이미지 1/3 Leader Impression i10A-LE Battery Pack Replacement: 2 단계, 이미지 2/3 Leader Impression i10A-LE Battery Pack Replacement: 2 단계, 이미지 3/3
    • Use the plastic prying tools to crack open the back of the device.
    • Once cracked, use more plastic prying tools to fully remove the back panel. A popping noise will occur when each clip is opened.
    • Remove the back panel and set aside.
  3. Leader Impression i10A-LE Battery Pack Replacement: 3 단계, 이미지 1/2 Leader Impression i10A-LE Battery Pack Replacement: 3 단계, 이미지 2/2
    • The battery pack is glued to the device.
    • Use a spudger to pry the battery pack from the glue.
    • Desolder the positive (red) and negative (black) power leads.
결론
riley seyffert
회원 가입일: 09/12/16
201 평판
안내서 2개 작성하였습니다
Western Carolina University, Team 1-3, Virtue Fall 2016 Western Carolina University, Team 1-3, Virtue Fall 2016 회원
WCU-VIRTUE-F16S1G3
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 585
