주요 콘텐츠로 건너뛰기
Leader Impression i10A-LE Front Facing Camera Replacement
필요한 것
  1. Leader Impression i10A-LE Front Facing Camera Replacement, Front Facing Camera: 1 단계, 이미지 1/2 Leader Impression i10A-LE Front Facing Camera Replacement, Front Facing Camera: 1 단계, 이미지 2/2
    • Start by prying the back off by using plastic opening tools.
    • Slide the flat end of the plastic tools into the seam device.
    • Using another plastic tool, slowly pry along the seam until the back pops off.
  2. Leader Impression i10A-LE Front Facing Camera Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Reminder to disconnect the battery.
    • Locate the Camera in the top left corner of the Leader Impression.
    • Using the tweezers, remove the bottom of the camera from the motherboard.
    • The top of the camera will detach as you pull upward.
  3. Leader Impression i10A-LE Front Facing Camera Replacement: 3 단계, 이미지 1/1
    • Remove the camera from it's slot.
결론
Crystal Dorrian
회원 가입일: 09/12/16
231 평판
안내서 2개 작성하였습니다
Western Carolina University, Team 1-3, Virtue Fall 2016 Western Carolina University, Team 1-3, Virtue Fall 2016 회원
WCU-VIRTUE-F16S1G3
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 7
전체 시간: 130
