주요 콘텐츠로 건너뛰기
Leader Impression i10A-LE Speakers Replacement
필요한 것
  1. Leader Impression i10A-LE Speakers  Replacement, Speakers: 1 단계, 이미지 1/1
    • Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Speakers  Replacement: 2 단계, 이미지 1/3 Leader Impression i10A-LE Speakers  Replacement: 2 단계, 이미지 2/3 Leader Impression i10A-LE Speakers  Replacement: 2 단계, 이미지 3/3
    • Start by prying the back off by using plastic opening tools
    • Using the plastic tools slide the flat end into the device.
    • Gently pry the back piece until you hear a popping noise.
    • Once the back is loose, remove it from the device and set aside.
  3. Leader Impression i10A-LE Speakers  Replacement: 3 단계, 이미지 1/3 Leader Impression i10A-LE Speakers  Replacement: 3 단계, 이미지 2/3 Leader Impression i10A-LE Speakers  Replacement: 3 단계, 이미지 3/3
    • Use the spudger to pry both of the speakers from the tablet.
    • Follow both sets of speaker wires to the motherboard where they are connected.
    • Desolder the wire connections from the motherboard.
결론
jcg
회원 가입일: 11/14/16
101 평판
안내서 1개 작성함
Western Carolina University, Team 1-3, Virtue Fall 2016 Western Carolina University, Team 1-3, Virtue Fall 2016 회원
WCU-VIRTUE-F16S1G3
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 8
전체 시간: 140
