소개
If the laser is not turning on, or flickering, the problem may be caused by a faulty leaf spring. In order to replace this part, follow the steps in this guide.
부품
부품은 필요하지 않습니다.
  1. Place the blaster upside down on the table, and remove the screw in the bottom of the handle.
    • Place the blaster upside down on the table, and remove the screw in the bottom of the handle.
    • Remove the battery door and take the batteries out.
  2. Set the blaster on its side with the screws facing up (the blaster will be placed on its left side). Remove all 14 phillips head, 8.2 mm screws and set them aside. Lift the side of the blaster off exposing its internal parts. Lift the side of the blaster off exposing its internal parts.
    • Set the blaster on its side with the screws facing up (the blaster will be placed on its left side). Remove all 14 phillips head, 8.2 mm screws and set them aside.
    • Lift the side of the blaster off exposing its internal parts.
  3. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Work the trigger to ensure the problem is the switch not making a proper connection.
    • Work the trigger to ensure the problem is the switch not making a proper connection.
    • Remove the retaining phillips head 10.2 mm screw below the switch.
  5. Use a hot soldering iron to melt the solder of the two wires at the rear of the switch.  Take note that the red wire leads from the top of the switch.
    • Use a hot soldering iron to melt the solder of the two wires at the rear of the switch. Take note that the red wire leads from the top of the switch.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jeffrey Sargeant
회원 가입일: 2014년 02월 24일
318 평판
안내서 1개 작성함
Michigan Tech, Team 5-8, Lauer Spring 2014 Michigan Tech, Team 5-8, Lauer Spring 2014 회원
MTU-LAUER-S14S5G8
3 회원들
안내서 9개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 11
전체 시간: 1,361
