주요 콘텐츠로 건너뛰기
N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide
필요한 것
  1. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide, Leaf Spring Switch: 1 단계, 이미지 1/1
    • Place the blaster upside down on the table, and remove the screw in the bottom of the handle.
    • Remove the battery door and take the batteries out.
  2. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: 2 단계, 이미지 1/3 N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: 2 단계, 이미지 2/3 N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: 2 단계, 이미지 3/3
    • Set the blaster on its side with the screws facing up (the blaster will be placed on its left side). Remove all 14 phillips head, 8.2 mm screws and set them aside.
    • Lift the side of the blaster off exposing its internal parts.
  3. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: 3 단계, 이미지 1/1
    • Work the trigger to ensure the problem is the switch not making a proper connection.
    • Remove the retaining phillips head 10.2 mm screw below the switch.
  4. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: 4 단계, 이미지 1/1
    • Use a hot soldering iron to melt the solder of the two wires at the rear of the switch. Take note that the red wire leads from the top of the switch.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jeffrey Sargeant
회원 가입일: 02/24/14
354 평판
안내서 1개 작성함
Michigan Tech, Team 5-8, Lauer Spring 2014 Michigan Tech, Team 5-8, Lauer Spring 2014 회원
MTU-LAUER-S14S5G8
3 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 1,938
