주요 콘텐츠로 건너뛰기
LeapFrog LeapPad 2 Rear Camera Replacement
필요한 것
  1. LeapFrog LeapPad 2 Rear Camera Replacement, Battery: 1 단계, 이미지 2개 중 1개 LeapFrog LeapPad 2 Rear Camera Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the tablet so the back is visible.
    • One at a time, remove the battery covers by sliding them towards the sides and away from the center of the device.
  2. LeapFrog LeapPad 2 Rear Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the AA batteries from both battery compartments of the device.
  3. LeapFrog LeapPad 2 Rear Camera Replacement, Rear Cover: 3 단계, 이미지 3개 중 1개 LeapFrog LeapPad 2 Rear Camera Replacement, Rear Cover: 3 단계, 이미지 3개 중 2개 LeapFrog LeapPad 2 Rear Camera Replacement, Rear Cover: 3 단계, 이미지 3개 중 3개
    • Use a Phillips #1 screwdriver to remove the following screws from the device:
    • Four 7.0mm Phillips screws
    • Three 6.0mm Phillips screws
    • Two 10.0mm Phillips screws
    • These two screws are behind the barcode decal on the bottom of the device. Expose the screws by puncturing, cutting, or peeling the barcode decal.
  4. LeapFrog LeapPad 2 Rear Camera Replacement: 4 단계, 이미지 3개 중 1개 LeapFrog LeapPad 2 Rear Camera Replacement: 4 단계, 이미지 3개 중 2개 LeapFrog LeapPad 2 Rear Camera Replacement: 4 단계, 이미지 3개 중 3개
    • Use a small plastic opening tool to begin separating the colored front cover from the white rear cover of the device.
    • With one hand on the front cover and one hand on the rear cover, start from the bottom of the device and begin pulling the pieces apart.
    • The most stubborn tabs holding the front and rear together are along the top edge of the tablet around the game cartridge slot. This will most likely be the last area that separates, and it may require a moderate amount of force.
    • Once only the top edge remains connected, simultaneously pull the rear cover backwards away from the front cover and upwards towards the top of the device. This should release the last remaining tabs holding the pieces together.
  5. LeapFrog LeapPad 2 Rear Camera Replacement, Rear Camera: 5 단계, 이미지 2개 중 1개 LeapFrog LeapPad 2 Rear Camera Replacement, Rear Camera: 5 단계, 이미지 2개 중 2개
    • Open the camera ribbon cable connector by lifting on the brown latch with a plastic opening tool or a finger until it is in a vertical position.
    • Failing to do this correctly could result in damage to the cable and/or connector.
  6. LeapFrog LeapPad 2 Rear Camera Replacement: 6 단계, 이미지 2개 중 1개 LeapFrog LeapPad 2 Rear Camera Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use flat tweezers or fingers to pull the rear camera ribbon cable out of the motherboard's camera connector.
    • If the connector is properly open, disconnecting the ribbon cable should require little to no force.
  7. LeapFrog LeapPad 2 Rear Camera Replacement: 7 단계, 이미지 2개 중 1개 LeapFrog LeapPad 2 Rear Camera Replacement: 7 단계, 이미지 2개 중 2개
    • Lift the camera body out of the plastic frame by using two small plastic opening tools as follows:
    • Place one opening tool directly under the base of the camera ribbon cable and camera body, applying upward pressure.
    • At the same time, use the other tool to release one of the clips on the left or the right of the camera body.
    • The left side of the camera body is shown here as the top, with the right side shown as the bottom.
    • Be careful not to bend the retaining clips too far as this can damage them.
결론
작성자
2다른 기여자 명과 함께
Chase Mamatey
회원 가입일: 10/05/16
326 평판
안내서 9개를 작성함
USF Tampa, Team 1-5, Sullivan Fall 2016 USF Tampa, Team 1-5, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S1G5
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 15
전체 시간: 551
