소개
The LeapFrog LeapPad 32400 has a large front screen which may break or not function properly requiring it to be replaced.
In this guide you will be replacing the screen component for this device. To do this you will be working on both the front and internal components. Caution is to be used when pulling out the screen as it is quite easy to damage or break the outer covering.
Check the troubleshooting page for symptoms to make sure this guide is the best route: LeapFrog LeapPad #32400 Troubleshooting Page
필요한 것
Turn the tablet so the back is facing up.
Remove the battery covers by sliding the covers towards the sides and away from the center of the device.
Remove three 7 mm screws using a Phillips #1 screwdriver.
Remove the single 6 mm screw using a Phillips #1 screwdriver.
Remove the single 10 mm screw using a Phillips #1 screwdriver.
Use a small plastic opening tool to separate the colored front cover from the white rear cover of the device.
With one hand on the front cover and one hand on the rear cover, start from the bottom of the device and pull the pieces apart.
Once only the top edge remains connected, pull the rear cover backwards away from the front cover and upwards towards the top of the device. This should release the last remaining tabs holding the pieces front and rear cover together.
Remove the single 10 mm screw from the device using a Phillips #1 screwdriver.
Remove the single 7 mm screw from the device using a Phillips #1 screwdriver.
