주요 콘텐츠로 건너뛰기
LeapFrog LeapPad Platinum Motherboard Replacement
필요한 것
  1. LeapFrog LeapPad Platinum Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Place your tablet on a flat surface with the screen facing down.
  2. LeapFrog LeapPad Platinum Motherboard Replacement: 2 단계, 이미지 1/2 LeapFrog LeapPad Platinum Motherboard Replacement: 2 단계, 이미지 2/2
    • Using a plastic opening tool, pry off the plastic border by inserting it in the space between the green bumper and the white plastic on the edge of the tablet.
    • The border snaps into place, so don't be too worried if you hear a cracking noise while prying it off.
  3. LeapFrog LeapPad Platinum Motherboard Replacement: 3 단계, 이미지 1/2 LeapFrog LeapPad Platinum Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove the 11 Phillips screws (8.0 mm) located around the edge of the back cover with a Phillips screwdriver.
  4. LeapFrog LeapPad Platinum Motherboard Replacement: 4 단계, 이미지 1/1
    • Pull the back cover off of your device.
  5. LeapFrog LeapPad Platinum Motherboard Replacement: 5 단계, 이미지 1/3 LeapFrog LeapPad Platinum Motherboard Replacement: 5 단계, 이미지 2/3 LeapFrog LeapPad Platinum Motherboard Replacement: 5 단계, 이미지 3/3
    • Wedge a plastic opening tool underneath the battery and lift the battery up.
    • The battery is held in place by an adhesive strip, so it can be difficult to pry off.
  6. LeapFrog LeapPad Platinum Motherboard Replacement: 6 단계, 이미지 1/1
    • The battery has red, black, and white wires that are all connected to the motherboard through a plastic clip. Unplug this plastic clip to fully remove the battery from your device.
  7. LeapFrog LeapPad Platinum Motherboard Replacement, Motherboard: 7 단계, 이미지 1/2 LeapFrog LeapPad Platinum Motherboard Replacement, Motherboard: 7 단계, 이미지 2/2
    • Locate the white ribbon cable connected to the motherboard.
    • Disconnect the cable by flipping up the metal tab on the connector and sliding the cable out.
  8. LeapFrog LeapPad Platinum Motherboard Replacement: 8 단계, 이미지 1/2 LeapFrog LeapPad Platinum Motherboard Replacement: 8 단계, 이미지 2/2
    • Locate the black ribbon cable which is connected to the motherboard.
  9. LeapFrog LeapPad Platinum Motherboard Replacement: 9 단계, 이미지 1/2 LeapFrog LeapPad Platinum Motherboard Replacement: 9 단계, 이미지 2/2
    • Remove the three 4.0 mm Phillips screws located in the corners of the motherboard.
  10. LeapFrog LeapPad Platinum Motherboard Replacement: 10 단계, 이미지 1/1
    • Lift up the front edge of the motherboard.
    • Lift the volume-control button out of the device and set it aside.
  11. LeapFrog LeapPad Platinum Motherboard Replacement: 11 단계, 이미지 1/1
    • Gently tug upwards on the red and black twisted wires located near the button you just removed to release the black rubber base they are connected to from the device.
    • This does not take much force, so it is likely that this piece will pop out of place when initially lifting the motherboard.
  12. LeapFrog LeapPad Platinum Motherboard Replacement: 12 단계, 이미지 1/2 LeapFrog LeapPad Platinum Motherboard Replacement: 12 단계, 이미지 2/2
    • Rotate your device 180 degrees so the the motherboard is on your right-hand side and gently lift the front edge of the motherboard to reveal an orange sheet of plastic.
    • Disconnect the orange sheet from the motherboard by lifting the metal tab on the connector (as you did for the cables in steps 1 and 2), and lift the motherboard completely out of the device.
결론
Kaitlyn Kinerk
회원 가입일: 01/26/16
263 평판
안내서 1개 작성함
UW Tacoma, Team 1-5, Rose Winter 2016 UW Tacoma, Team 1-5, Rose Winter 2016 회원
UWT-ROSE-W16S1G5
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 14
전체 시간: 2,089
