주요 콘텐츠로 건너뛰기
LeapFrog LeapPad Platinum Speaker Replacement
필요한 것
  1. LeapFrog LeapPad Platinum Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Place your tablet on a flat surface with the screen facing down.
  2. LeapFrog LeapPad Platinum Speaker Replacement: 2 단계, 이미지 1/2 LeapFrog LeapPad Platinum Speaker Replacement: 2 단계, 이미지 2/2
    • Using a plastic opening tool, pry off the plastic border by inserting it in the space between the green bumper and the white plastic on the edge of the tablet.
    • The border snaps into place, so don't be too worried if you hear a cracking noise while prying it off.
  3. LeapFrog LeapPad Platinum Speaker Replacement: 3 단계, 이미지 1/2 LeapFrog LeapPad Platinum Speaker Replacement: 3 단계, 이미지 2/2
    • Remove the 11 Phillips screws (8.0 mm) located around the edge of the back cover with a Phillips screwdriver.
  4. LeapFrog LeapPad Platinum Speaker Replacement: 4 단계, 이미지 1/1
    • Pull the back cover off of your device.
  5. LeapFrog LeapPad Platinum Speaker Replacement: 5 단계, 이미지 1/3 LeapFrog LeapPad Platinum Speaker Replacement: 5 단계, 이미지 2/3 LeapFrog LeapPad Platinum Speaker Replacement: 5 단계, 이미지 3/3
    • Wedge a plastic opening tool underneath the battery and lift the battery up.
    • The battery is held in place by an adhesive strip, so it can be difficult to pry off.
  6. LeapFrog LeapPad Platinum Speaker Replacement: 6 단계, 이미지 1/1
    • The battery has red, black, and white wires that are all connected to the motherboard through a plastic clip. Unplug this plastic clip to fully remove the battery from your device.
  7. LeapFrog LeapPad Platinum Speaker Replacement, Speaker: 7 단계, 이미지 1/2 LeapFrog LeapPad Platinum Speaker Replacement, Speaker: 7 단계, 이미지 2/2
    • Remove the brown speaker board located on the left side of the LeapPad by removing the following screws holding it in place:
    • Four 3.0mm Phillips screws
    • One 7.0mm Phillips screw
  8. LeapFrog LeapPad Platinum Speaker Replacement: 8 단계, 이미지 1/2 LeapFrog LeapPad Platinum Speaker Replacement: 8 단계, 이미지 2/2
    • Locate the circular plastic speaker cover, remove the two 5.0mm Phillips screws holding it in place, and gently lift the cover away from the device.
  9. LeapFrog LeapPad Platinum Speaker Replacement: 9 단계, 이미지 1/1
    • Lift up the speaker board and locate the white ribbon attached to its underside.
    • Fully remove the speaker board from the device by gently pulling the ribbon cables out of the slot.
    • Be gentle when working with the ribbon as it can be damaged easily.
    • Tweezers or a pointed plastic spudger will help guide the ribbon back through the black tabs when reassembling your device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Leann Nguyen
회원 가입일: 02/02/16
171 평판
안내서 1개 작성함
UW Tacoma, Team 1-5, Rose Winter 2016 UW Tacoma, Team 1-5, Rose Winter 2016 회원
UWT-ROSE-W16S1G5
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
Thanks for the tutorial: Where can we find the replacement speaker?
Gigi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 13
전체 시간: 1,373
